CPU Heatsinks
I used a couple of AMD CPU AM2 Heatsinks with no fans.
They are made of Thermoalloy and are very massive.
You can drill and tap them very easily.
The operating temp with these Heatsinks is arround 55°C after an hour at medium listening volume.
Just be sure that the Temperature between the LM3886 and the heatsink is not more than 3-5 °C. If not, check if the layer of silicon heatsink compound is not too thick and that the LM is well tightened.
I've got 1x ~4" x 6" (by 2inch thick) heat sink left over from my F5 build.
I've got the gainclone chips (lm3886 I think), just wondering what the heat sink requirements are for a build?
