Old 19th May 2011, 06:53 PM   #1
sunny is offline sunny  India
Send a message via Yahoo to sunny
Default TDA 7294 Bridge Amp maximum Power output
I have succesfully completed building TDA 7294 Bridge Amp using +/-35 volts. As per the data sheet it is mentioned that power output with 8 ohms speaker is 150 watts.Is it RMS power or maximum power output and what is the PMPO output of TDA 7294 bridge AMP?
Thanks,
Sunny.
Old 21st May 2011, 10:59 PM   #2
Vigier is offline Vigier  Netherlands
PMPO means nothing. It is only used by cheap & crappy "audio"-brands.
Old 22nd May 2011, 12:35 AM   #3
nigelwright7557's Avatar
150 watts peak or 75 watts RMS.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 30th May 2011, 03:26 PM   #4
amptech is offline amptech  Scotland
Send a message via MSN to amptech
I would agree with vigier there pmpo..is a company's way of trying to make some low end/cheap units 'sound' better so people will buy them....always go for the true rms power instead..
@sunny..place a meter on the o/p of your bridged unit and read the ac o/p voltage at full power and use ohms law to get your answer, oh and don't bridge your amp at 4 ohms or it will fail...
TDA 7294 Bridge amplifier Questions sunny Chip Amps 10 22nd April 2011 04:27 PM
tda 7294 power amp laki101 Chip Amps 28 27th December 2010 04:58 PM
Amp on TDA 7294 maris24 Chip Amps 4 17th November 2006 10:11 AM
TDA 7294 amp with horns problems Bubba Zanetti Chip Amps 1 30th December 2005 02:00 PM
Page generated in 0.07814 seconds (75.69% PHP - 24.31% MySQL) with 10 queries
