My new baby
My new baby
Old 12th August 2003, 10:09 PM   #1
GrahamnDodder is offline GrahamnDodder  United States
Default My new baby
It's not a gainclone, but it is a chip amp, so I am posting here. It is a CMoy headphone amp, built around the Burr-Brown 2132 opamp. (The 3875-based) gainclone is already underway....
Way beneath most of you guys. But it is the first amp I ever built, so I thought it deserved a decent DIY'd case.
Alas, a tree had to die. I used a small board of red oak, cut into three pieces. The first two had a space cut out with a drill and jigsaw, then I glued them together for the box look.
Still had to shave the middle piece down to get about 1/8" wall for mounting the Pansonic pot and the LED. Used a Dremel for that.
I love the sound, even though I have heard the better-rated META42 design I am recasing in an old cigar box. (Maybe it sounds better because I built it...) That project is on hold, however, as I have the bug bad enuf now to be doing a GainClone.
I finished this a month ago, but had been waiting for the next incoming Digikey order for a better nob. The tiny one I had just didn't look right.
There is some sloppiness inside (and some outside!) so please be gentle with the comments....
Thanks to all for your ongoing help!
GnD
I had the right to remain silent. I just didn't have the ability. (Comedian Ron White)
Old 12th August 2003, 10:10 PM   #2
Back view - 1/4" input and power switch...
Old 12th August 2003, 10:12 PM   #3
This is the whole setup, with the XM Satellite Radio SkyFi receiver (my favorite source) and Sony MDR-7506 headphones, which I listen to all day whe I am at my desk at work...
Old 12th August 2003, 10:15 PM   #4
The guts, for those not familiar with the CMoy amps:
Old 12th August 2003, 10:17 PM   #5
...and the circuit board close-up.
Way more info available on this very easy first DIY project at www.head-fi.org.
Also, a complete tutorial on the circuit at www.tangetsoft.net, under audiologica.
GnD
Old 12th August 2003, 10:24 PM   #6
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
You have style, taste, nice pictures and a good camera.
Oops, and Guts too
Veeeeeerrrry nice wooden box.
/Hugo
Old 12th August 2003, 10:31 PM   #7
tschrama is offline tschrama  Netherlands
Ooohhhhhh .... I'm completely in love with this beautiful piece of work ... Howabout a small BJT to buffer the poor opamp output.. If you build something like that with a bit more audiophile guts it would be a niceeeeeeee hi-end product...
regrads,
Thijs
Old 12th August 2003, 10:35 PM   #8
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
Default The Woodwright
Sweet!
A box that Roy Underhill himself would be proud of (http://www.pbs.org/wws/program/index.html), assuming that none of those Norm Abrams power things were used.
How long does the battery last?
-Dave
Old 12th August 2003, 10:40 PM   #9
Thanks!
Battery lasts about 50 hours at pretty decent volume. Very simple, with nice, clean DC.
I am thinking of a similar case, albeit larger, for the gainclone I am building.
Roy would frown on my jigsaw and palm sander. Not to mention the Dremel...
GnD
Old 12th August 2003, 10:42 PM   #10
tschrama-
It was my very first DIY project. The guts had to be pretty simple. Nevr underestimate the depth of my incomprehension....
My new babyHide this!Advertise here!
My new baby amp suzyj Solid State 21 19th May 2009 03:11 PM
My baby is HOT!! jazzy Pass Labs 18 9th June 2003 10:37 AM
A Baby Zen V2 jh6you Pass Labs 13 1st October 2002 03:44 PM
Copyright ©1999-2017 diyAudio
