Can I use this as a preamp? Can I use this as a preamp? - diyAudio
Old 17th May 2011, 10:10 PM   #1
Jujo is offline Jujo
Default Can I use this as a preamp?
Hi, everyone!
I just found a dead simple schematic for a LM386-based amp - http://www.beavisaudio.com/library/L..._Schematic.jpg - and was wondering if instead of connecting a speaker to it, I could connect an amp to it and use it as a preamp for a guitar?
If not, can you suggest me any simple schematic for a guitar/bass preamp?
thanks
Old 17th May 2011, 11:35 PM   #2
Minion is offline Minion  Canada
Yes you can do that ....... The LM386 has a very Lo-Fi sound that some poeple like for guitar but I never really liked them ......
Cheers
Old 17th May 2011, 11:36 PM   #3
Well, I'm looking for a simple preamp. Which one would you recommend for this purpose?
Old 18th May 2011, 03:42 PM   #4
Arty is offline Arty
an opamp.
Old 18th May 2011, 06:22 PM   #5
Like what? And is there any diagram that I could use?
Old 18th May 2011, 06:56 PM   #6
Designing Op Amp Audio PreAmplifiers
before you ask, i enterd into google the following keywords:
opamp preamp circuit.
hapy building.
go for split supply at your first prototype, 2 9v batteries in series should be more than enough.
Old 18th May 2011, 10:06 PM   #7
Try this site ....
DIYstompboxes.com - Index
It is a Forum with a lot of Stomp Box builds with Schematics and layouts etc ....
That is Basicly all you need , just a Preamp with Overdrive and Tone controlls , there are also kits you can buy for a wide variety of different pedals .....
Cheers
Can I use this as a preamp?Hide this!Advertise here!
Running a tube preamp into a solid state preamp? Pckid212 Solid State 5 6th January 2013 10:12 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Copyright 1999-2017 diyAudio
