Looking to hire someone to help with simple headphone amplifier design
Old 17th May 2011, 04:52 PM   #1
FasterHorses is offline FasterHorses
Default Looking to hire someone to help with simple headphone amplifier design
Hi All;
I have a few small projects in mind that are over my head. I'm trying to find someone that would be willing to help me finish and draft the idea out so I can have it produced!
In short, I want to recreate the headphone amplifier stages from various older portable cd/cassette/dat players (nak 550, sony d8, sony dd9) in modular amplifier form for the Hifiman 801. It would entail taking the amp stage from the schematic, adjusting the power input (the power from the Hifiman is 5V and 7.4V, most of these portable units require much lower voltage), and plotting these in a program which I can then submit for production (I was thinking aapcb.com but am open to any suggestions!).
It's pretty straightforward, but I'm more interested in the final project than the trial and error of where I go wrong in the design, or trying to get Eagle working right for the required files.
If anyone would be willing to help with this, I would happily compensate for your time. Just drop me a PM and we'll go from there. I'd happily provide more info here if there's any interest.
Tim
Old 17th May 2011, 07:02 PM   #2
Arty is offline Arty
copy the chematic from the exsisting board, and use a simple LDO to get the required voltage for them from the modular amp.
Old 17th May 2011, 07:15 PM   #3
Thanks Arty; the issue is that the board this has to fit on is very specific; I'd need to have it laid out nicely on there; I'm also concerned there'd be some things I'm missing. To someone that has some experience in simple construction these are no big deal; but to me, I'd likely bungle a good amount of it up!
Old 17th May 2011, 07:42 PM   #4
qusp is offline qusp  Australia
qusp's Avatar
are you sure it was the amplifier design that made these headphone outputs sound so good? most will have used fairly old, standard low voltage opamps
Old 17th May 2011, 07:45 PM   #5
qusp, you're correct. We can use "good" as a relative term, but yes, opamps played a large part (for analog sources) and i'm sure the early 90's tech D/A converters played a large part as well; there's people on both sides for the SQ of those, but one thing we can agree on is that they're "unique."
There's definitely a lot more that contributed to the sound signature of the units; this is, like most projects, just an exercise and an experiment!
Looking to hire someone to help with simple headphone amplifier designHide this!Advertise here!
Looking to hire someone to help with IC amp design! FasterHorses Chip Amps 1 21st May 2011 05:32 PM
Simple Headphone Distribution Amplifier TheSeekerr Headphone Systems 7 28th November 2010 11:08 AM
This happens when you hire a good designer. Cassiel Tubes / Valves 129 25th November 2009 03:12 AM
A simple Headphone amplifier. Kapibara Headphone Systems 3 20th July 2007 08:55 AM
My DIY headphone amplifier design cetoole Headphone Systems 26 9th December 2005 01:39 PM
