Old 10th May 2011, 01:56 PM   #1
Default HELLP ME TO HACK 2.1 AUDIO SYSTEM
I have 2 years older 2x2.1 audio systems
i wanna build 5.1 channel PC Home theater usin their parts
they use 6*TDA2030A Monolithic IC (in 2*2.1 systems), yeah i know Sub channel need more power.
can i use TDA2050, single or bridge mode ?
4*3300uf 25v rating Caps ( Yes I know I need more caps)
2*12-0-12VAC, 1.5Amp Transformers, can i use one for each channel ? yeah i know the Sub channel need different transfarmer
some couple of ZDiodes, diodes, resisters, film Caps, RCA jacks volume pots blaaa blaaaaaaa blaaaa
can i use this PCB layout ? from ST
Old 11th May 2011, 08:55 AM   #2
diptangshu's Avatar
Send a message via Yahoo to diptangshu
you can use the pcb layout for sats but not for the sub. for sub you have to use different PCB for TDA2050 in bridge mode.
Old 14th May 2011, 10:38 AM   #3
Ok diptangshu
can i use tda2030a with 12v 1.5A for single channel for 6" or 8" woofer and 3" tweeter ?
if its OK or need any crossover ?
and another question
is there any Tripath IC's available in india ?
Old 15th June 2011, 01:18 PM   #4
diptangshu's Avatar
Yes you can.
If you use Xover it will be good for system.
Couldnt get you....
Hack Things Better jkeny Everything Else 6 12th December 2009 02:35 AM
Yet another do-nothing tOOb hack. kenpeter Tubes / Valves 17 21st October 2009 02:41 AM
hellp dirty hirry amp? zakzak Solid State 2 17th July 2008 03:33 PM
Hellp with AudioTester 2.1 a007udio Multi-Way 6 24th March 2007 12:26 PM
Hellp from Guraqiy Esra Yeknom Introductions 3 16th January 2004 12:50 PM
Page generated in 0.09164 seconds (65.66% PHP - 34.34% MySQL) with 11 queries
