Old 11th August 2003, 04:32 AM   #1
Default NonInverting Gain Amounts
Has anyone experimented with other gain than 20-30 which is what showed up as the norm when I searched this forum? General consensus is that the lower values the better, but has anyone tried gains between 10-18 or so? Is stability THAT big of a problem below gain=20?
Reason I ask, is that I don't need the power of the 3875 or even the 1875, but thought less gain would be better than attenuation of the input. My rails will be +/- 23 VDC and I'll be using the 1875.
Nik
Old 11th August 2003, 05:35 PM   #2
ghetto is offline ghetto  United States
You should try basing your design on the inverting technique, you can even go as far as gain=1, most people believe it sounds better too
Old 11th August 2003, 05:54 PM   #3
jackinnj's Avatar
Nat Semi is pretty clear on setting the gain, given the supply rails and load.
Old 11th August 2003, 05:55 PM   #4
For many reasons, I'm sticking with the non-inverting amp at the moment. The main one is too many factors affect the feedback circuit on an inverting amp. There are less variables on the noninverting one: 2 resistors, and signal ground. On the inverting amp, you have the attenuator, dc blocking cap, wire, etc.
Gain Blockwith Variable Loop Gain Bonsai Solid State 17 11th July 2008 02:40 PM
Peavey 2000 Drawing huge amounts of current. andrew58 Solid State 6 20th October 2007 05:00 PM
Karlson - "equal amounts of energy"- what did he mean? freddi Multi-Way 8 25th May 2007 06:44 PM
Heretical Unity Gain line stage PLUS a little gain ? yagas Tubes / Valves 7 24th January 2006 01:30 PM
Switching Large amounts of FETs fr0st Parts 20 30th August 2003 10:19 AM
Page generated in 0.07682 seconds (67.83% PHP - 32.17% MySQL) with 11 queries
