| Chip Amps Amplifiers based on integrated circuits |
Hi Diy's
this is my first diy I wanna build 5.1 channel with 2xLM1876 for "rear" and "front" channels. And 1xLM4782 is a 3 channel amp, 2 channels bridged for "Sub woofer" and 1 channel for "center". Is it possible ...? if it is possible then plz any one advice abt circuit diagram and power supply |
#2 |
LM1876 is a 2xLM1875
can i use the attached circuit diagram for my project.. ? i get the circuit diagram from elliott sound products and split power supply too |
#3 |
i wants to be circuit diagram for amplifier circuit description for I.C_TDA-7375a
#4 |
LM1876 is a 2x1875 so can i use this circuit ??
i get it from "Elliot Sound Products" |
#5 |
By the time you add the costs of enclosures, heatsinks and transformers and PSU caps, you are probably way over the cost of a budget AV receiver, offering things like remote control and all kinds of bells and whistles.
If cost is no objection, you can certainly do this, but start with the costs of the items mentioned, building up the PCB's is cheap in comparison. |
#6 |
Toxicaudio: You cannot use Rod Elliots LM1875 circuit for wiring LM1876. The pinouts are different.
Your project is not impossible, but will need a lot of work and preparation as "digit" pointed out in his post. I have been working on a project to build a 5.1 amp using 6 LM3886 and I have redesigned it multiple times over the last 4 years. It is still not ready. ![]() Best of Luck on your project.
Regards, Din |
#7 | |
I appreciate ur patience Yes u r right pinnouts are different i get circuit from national semi conductors Now the problem is chip availability i am livin in small town near vijayawda, andhrapradesh (INDIA) where can i get them ??? any price details ?? (LM1875, LM1876, LM3886) to order them searched on local shops they even don't know those are audio amps please advice ..................
#8 |
#9 |
THX u very much DIGITS
#10 |
Ohhh guys i need to creat new thread on TDA2030a
| A&R Cambridge A60 Amp left channel very low distorted | barhardy | Solid State | 3 | 18th May 2010 08:13 AM |
| Hypex ST, HG & HxR in 7 channel amp | robomatique | Class D | 8 | 19th November 2007 05:02 PM |
| Active crossover & buffer stage for a 5 channel amp | sunil | Chip Amps | 9 | 15th December 2004 07:10 AM |
| JM Labs & Focal - Centre channel / Difference between Midrange & midbass speakers | mark.carline | Multi-Way | 5 | 18th May 2004 06:03 PM |
| My 4 channel car Amp distorting on 1 channel (large pics) | MikeHunt79 | Car Audio | 9 | 3rd September 2003 06:41 AM |
| Page generated in 0.12920 seconds (79.37% PHP - 20.63% MySQL) with 11 queries |
