My Amp + Speaker Build (Incomplete w/ pictures)
Old 8th November 2011, 12:23 AM   #11
TheLaw117 is offline TheLaw117  United States
I can't believe I started this project sometime in Febuary...Simply amazing...And I'm STILL not done yet! Yikes. It's a lot of work: much more than I really expected. Making sure you haven't f@cKed up your wiring when you are working with hundreds of dollars of equipment is pretty serious stuff. I'm going to check everything 9,000 more times to make sure I don't turn this into a $500 smoke machine.
Anyway, I took this picture with my phone, but I'm ALMOST there. Needs a few more finishing touches. But very close!
Since last time I installed the 4PDT output selector switch. It was suggested afterward that I should have used a relay or something, but I think this will be fine. There was bound to be long wire runs anyway due to some of my control boards etc. I have two 12VDC computer fans running at ~8V. One intaking cool air from under the subwoofer amp heatsink, and one as exhaust to the left of the trafo. cMoy Headphone amp in the lower left corner on a regulated +/- 6V power supply.
My Amp + Speaker Build (Incomplete w/ pictures)Hide this!Advertise here!
What amp to build for a ESL speaker? SM7UYJ Solid State 4 22nd October 2009 07:50 AM
Incomplete turntable project yildiray35 Analogue Source 15 29th April 2008 03:46 PM
line array build questions and pictures lolojr1 Multi-Way 18 15th April 2008 01:09 AM
A166 build pictures cwujek Full Range 22 9th November 2007 07:13 AM
Another New Build Pictures ( G' Amp ) Trout Tubes / Valves 2 6th November 2005 02:12 AM
