So, 16 Volt (or +/-8V) is the lowest.LM1875 datasheet:
Wide supply range 16V-60V
But sure there are other chips out there. Especially for lower voltages.
Oops - now that I look at the data sheet, 12v single ended is not possible. I was mislead by seeing references to 12V LM1875 circuits.
Perhaps I can back up and describe my need: I'm hoping for a significant audio upgrade to the existing LM-380 in the af output stage of a radio. I built a circuit with discreet components that sounded good through headphones but couldn't drive a small speaker adequately. I figure 2-5 watts into 4/8 ohms would be enough. I'm more interested in quality than quantity.
If anyone has suggestions for a great sounding chip amp or discreet amp circuit for single ended 12V supply that would deliver 2-5 watts, I'd appreciate it.
In 12V with 8 Ohm speaker, you can max get 2 Watt
With 4 Ohm speaker max 4 Watt
A small transistor amplifer is one option.
It could be simple.
But there are not many around. Somebody have to design.
Have a look at National other audio amplifiers:
Audio Home - Audio Amplifiers, Far Field Noise Suppression/Reduction, Boomer, Overture, Class D, Audio Speaker Drivers, Headphone Amps, Microphone Amps, Stereo, 3D Sound, Audio Subsystems, Audio Codecs
It could be simple.
why not try a small class A discrete amp then.
Thanks - that's a good idea. This is the circuit I built and sounded good but underpowered: Picasa Web Albums - BarryG
I'll search for a small class A circuit that looks good unless someone here can recommend one.
Use the TDA2040. The the bias comes on at 5 volts (+/- 2.5) so they will work fine at 12 volts. With the samples I have, the chip came on at 3 volts, as did the 2050. The LM1875 came on at 9 volts, so that's cutting it close if on battery power.
Listening tests and differentiating the output signal with the input shows no distortion when operating at low voltage (as long as you don't clip).
To get 5 clean watts with a 12 volt supply on a single ended amp, you need to go below 4 ohm loads.
Use the TDA2003. It has an optimized output swing for lower voltages.
Thanks - those Pentawatt chips look promising.Use the TDA2040. . . Use the TDA2003.
- Chip Amps
- 12V LM1875 circuit?
