| Chip Amps Amplifiers based on integrated circuits |
Hello everybody,
I have built a complete "chipamp" (amp + Psu) kit, double mono, powered by 2X300VA transformers. Sounds good, but compared to my small "NAD 3020" and to a big "Kenwood" L1000M, using the same loudspeakers, I feel a lake of bass, which is very frustrating. I was about to upgrade the caps of the PSU to Munsdorf 15000 microF/18mohm instead of the Panasonic 10000 microF/36mhom. Should I go this way or may be the limitation is part of the LM3886 itself ? In that case would be better to change for another type of amp (4981x or discrete) Any experiences will be appreciated. Thank You for the help. |
#2 |
hi
lake ? do you mean lack of bass would you want me to correct it ? ![]() moderation |
#3 |
How deep is the lake?
#4 |
lake of bass fishing?
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
#5 |
reminds me of this guy
#6 |
I actually swam on Lake Bass as a child. Areas of it are muddy.
#7 |
I don't think changing the caps will make much difference. The problem probably lies elsewhere. Can you measure the frequency response? Sometimes a bit of a tilt upwards will sound like a lack of bass. There's also the gain issue. Whatever's louder sounds better. When you listen, is the level the same? Is there any subtle oscillation going on? If the chip amp runs warm that's a possibility, and the tiniest amount of oscillation, IMHO, affects the sound. Where do the speaker returns physically connect in the amp in relation to the circuit grounds? It matters!
I used to be an audiophool like you but then I took an arrow to the knee. |
#8 |
sometimes old receivers have a bit of bass EQ even when tone controls are set flat. If they have a loop connection you can plug the chip amp up , bypassing the built-in amp and check difference there.
#9 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
It would help if you said what kit you've bought. I agree with Conrad, the lack of bass could easily be an overly bright sound. Brightness that I've experienced with chipamps I've fixed with relatively minor circuit and layout changes.
I think ideas are what you want to get rid of. I don't really like songs with ideas. - Leonard Cohen |
| Active RIAA lack off BASS | wabun | Analogue Source | 1 | 5th October 2010 07:33 PM |
| Class-D lack of sustained bass Myth | Zero Cool | Class D | 15 | 9th July 2009 05:41 AM |
| LM3886 bass amp | thomasst | Chip Amps | 9 | 6th July 2008 07:04 PM |
| lack of bass in a 6h30 design | SunRa | Tubes / Valves | 3 | 31st January 2007 09:54 PM |
| Flat bass of paralleled LM3886 | manuruthen | Chip Amps | 7 | 26th August 2005 08:59 AM |
| Page generated in 0.11575 seconds (64.42% PHP - 35.58% MySQL) with 11 queries |
