Old 24th April 2011, 03:29 PM   #1
losacco is offline losacco  United States
Default Beginner circuit needed
Looking for a good LM3886 beginner circuit with power supply. Any help would be appreciated.
Thanks.
Old 24th April 2011, 03:37 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Thanks.
I think if you use the search function you'll find about a zillion threads here with all the info you'd ever want
jan didden
/Another new issue: Linear Audio Volume 3!
Old 24th April 2011, 04:49 PM   #3
Minion is offline Minion  Canada
If you look in the Datasheet the basic LM3886 schematic is as beginner as it gets ......
Old 26th April 2011, 06:41 AM   #4
gootee is offline gootee  United States
Here are some basics about power supplies:
Unregulated Power Supply Design
The short thread linked below should have everything else you need, in order to understand a simple power supply:
Does a LM317 act like a transformer
You will need a dual-polarity power supply, i.e. both a positive and a negative power supply, to run most chipamp chips. Here is one:
LM338 regulated snubberized PSU for audio amplifiers (but remove the short across the secondary of T2 in the diagram)
You could, instead, use an unregulated power supply, which would be simpler.
Also look to post #68 of that thread, to get an amplifier circuit. Make two of them.
Go to National.com and download the LM3886 datasheet to find the pin numbers that correspond to the connections in the diagram.
Parts can be purchasd from mouser.com, digikey.com, and many other places on line.
Do some more reading, here, first.
Old 26th April 2011, 09:09 AM   #5
read
Decibel Dungeon
and
Elliot Sound Products (ESP)
regards Andrew T.
Guide needed. beginner in learning PCB (DIP-TRACE) chchyong89 Software Tools 16 20th July 2010 05:38 PM
TK2050 power switch advice needed from amp DIY beginner westsounds Class D 0 29th December 2009 12:35 PM
Beginner Project needed... Bow Solid State 1 18th October 2008 06:38 AM
Beginner symasym circuit analysis serj.t.s Solid State 18 8th May 2008 10:28 AM
simple circuit for beginner JAZZ2250 Tubes / Valves 4 8th April 2002 01:33 AM
Page generated in 0.11950 seconds (53.81% PHP - 46.19% MySQL) with 10 queries
