LM47XX series of chip amps
Old 7th August 2003, 08:06 PM   #1
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
Default LM47XX series of chip amps
Pretty much all of the LM38XX and LM18XX series of chips have been used by members here on these forums, and the OPA5XX chips have also been extensively toyed with, but I can't find any one who has tried the LM47XX chips.
The LM4700/LM4701 looks to be newer parts and asside from the lower power and slightly lower gain bandwidth they have superior specs such as slew rate and SNR. The LM4766 seems a good way to minimalise the gainclone idea even more, have only one chip.
I wonder why no one has tried them. Maybe I'll give them a go, the LM4701 is in a 9 pin package that might work nicely for smaller amps...
Old 8th August 2003, 12:09 AM   #2
Sandy H. is offline Sandy H.  United States
Sandy H.'s Avatar
I wish I could technically give you some information, but I can't. Maybe you've noticed a previously disregarded chipamp option.
I'll look to see if something good comes from it. Go for it, JoeBob! Even if it isn't a perfect performer, I'm sure someone will enjoy learning from your experiment.
Sandy.
Old 8th August 2003, 11:23 AM   #3
ted is offline ted
On coincidence I recently I prototyped a GC using a LM4700TF. The PS rails used were +/- 31 volts unloaded. The resulting THD @ 1 watt/8ohms was [ 100hz=.03%, 1Khz=.03%, 10Khz=.04%, 20Khz=.05% ]. Clipping wattage was 22W.
The 3886TF version was below my measurable limit of .01% from 100Hz to 20Khz.
I have a few LM4752T, which I was going to play around with since it has embedded feedback resistors but the big down-side were the output capacitors and a low maximum PS of (40v).
Good Luck on your experments.
Old 9th August 2003, 06:46 PM   #4
JoeBob's Avatar
I'm guessing these parts are biased at lower currents, to conserve power most likely. But since THD isn't everything I'd still like to try some out.
LM47XX series of chip ampsHide this!Advertise here!
New xa.5 series amps mert Pass Labs 31 28th July 2009 03:06 PM
FS: 3 Hafler DH-200 Series Amps Zero Cool Swap Meet 0 10th March 2008 01:07 PM
Has anyone compared the Chip amps against Class T amps? soongsc Chip Amps 3 24th July 2005 11:50 AM
OPAxxx chip series soundNERD Chip Amps 16 27th March 2004 12:33 PM
Are the outputs in the X series amps socketed? Apogee Pass Labs 2 23rd September 2002 10:35 PM
