Old 16th April 2011, 06:38 PM   #1
Default low pass filter issues
I built 3 stk amps 2 for mains and 1 for sub amp also built a low pass filter. I am splitting the input signal between the main amps and the sub amp problem is with everything hooked up the sub amp seems to have low output when used alone output is fine but when i plug in the main amps output drops. am i loading down the op amp in the low pass filter or what?any suggestions? ps main amps seem unaffected.
Old 16th April 2011, 07:47 PM   #2
Shoog's Avatar
Is there a buffer on the input to the LPF ?
Shoog
Old 16th April 2011, 11:52 PM   #3
no 2 39k resistors combine the input signals. circuit is a standard unity gain sellen key filter using a tlo82 (had a few handy)figured a opa2134 would be overkill.not sure whats happening!
Old 17th April 2011, 09:27 AM   #4
Shoog's Avatar
I think you need a unity gain buffer on the input.
Br Cornelius
Old 17th April 2011, 01:06 PM   #5
the low pass filter to the Bass only amp/speaker can be designed to sum the LF of both channels and act as a buffer and not load down the stereo signal and not interfere with the stereo crosstalk.
Use an MFB filter with a pair of summing resistors on it's Inverting Input.
All your problems go away. Just one opamp or discrete opamp and the right circuit wrapped around it is all you need.
This filter can have as many summing channels on the input as you need.
A 5channel surround sound system could have 5 summing resistors and the MFB would sum the bass signal from all 5 channels and send that filtered signal to the bass amp and speaker.
regards Andrew T.
Old 18th April 2011, 02:36 AM   #6
Thanks for the input guys sounds like exactly what I need anyone have a appropriate circuit or link to one.
Old 18th April 2011, 08:57 AM   #7
look up MFB filter.
regards Andrew T.
DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM stevep314 Analog Line Level 0 10th August 2010 09:15 PM
need help with low pass filter prezden Multi-Way 11 12th January 2009 08:04 AM
low pass filter AudioAddicted Car Audio 17 2nd November 2006 06:44 AM
NO low pass filter? jmar Digital Source 7 19th January 2006 12:53 PM
Low pass filter Fin Digital Source 2 29th December 2003 02:27 AM
Page generated in 0.09428 seconds (71.89% PHP - 28.11% MySQL) with 10 queries
