Old 15th April 2011, 07:44 PM   #1
beamsjr is offline beamsjr  United States
Default Chipamp questions
I recently purchased a chipamp from chipamp.com and assimbled it. I am using a 25x2 transformer and when I am running the amp I can hear the transformer buzzing. If I touch the transformer I can feel it vibrating. Is this normal?
Also the traces going to the LED burned off when I plugged it in, so the LED does not work. I have double and triple checked my connections and cant seem to figure out what I have done wrong.
The amp works great besides these few issues and sounds great.
Here is how I have the leads going to the power supply
|--- 25 --> AC1 with the line over it
|--- 0 --> AC1
|--- 25 --> AC2 with line over it
|--- 0 --> AC2
Please let me know what you think.
Old 15th April 2011, 09:16 PM   #2
ianpengelly's Avatar
Can you post some photos please?
Are you using the chipamp.com (BrianGT) boards?
Have you installed your diodes correctly?
It sounds like there is a short circuit causing the transformer to draw a lot of current and therefore vibrate as the magnetic field fluctuates.
Old 16th April 2011, 05:46 AM   #3
just be carfull not to pop your caps
If your power supply voltage is exceeding the "WV__ " working voltage maximum
is labeled right on your filter caps...
grab your meter and check OK
Questions on First Chipamp Buzzer Chip Amps 3 23rd June 2010 07:01 AM
Questions about building my first chipamp JDawg Chip Amps 9 23rd May 2010 04:21 PM
A few chipamp configuration questions GregH2 Chip Amps 3 15th February 2010 01:56 PM
Some Chipamp questions from a newbie. cyberspyder Chip Amps 3 17th November 2008 11:34 AM
Newbie chipamp questions. nodiak Chip Amps 3 2nd June 2008 12:44 AM
Page generated in 0.07589 seconds (59.72% PHP - 40.28% MySQL) with 10 queries
