Old 15th April 2011, 10:33 AM   #1
Location: Where the world's best tea come from:Kericho Kenya
Default Paralleled LM1876's
Hi guys,
Am planning to go bi-amp with lm1876 for mid+high.I chose these because of low distortion levels and easy construction.
For lows,i run into a problem:i have 2.7 ohm woofers,and am considering paralled 1876s to drive them.Can this work out?I read somewhere that paralleled amps 'drive each other' ,how do i go about this?
if there are no sparks,it probably doesn't work!
Old 15th April 2011, 10:35 AM   #2
Since you don't already know the answer nor the problems that you will face, I strongly suggest you are not ready for paralleling of chipamps.
2.7ohm driver is quite low impedance and an unusual value. Where did it come from?
regards Andrew T.
Old 15th April 2011, 11:07 AM   #3
Its just 20 wpc,not bad to start of with.
Most of you wont consider them as woofers,i got them from a panasonic boombox.
Old 15th April 2011, 08:09 PM   #4
you should not jump into that conclusion, it is still a bass driver, i bet many peeps here used even worse ones in their life at least one time.
and who knows, they might actualy be suitable for your needs, in that case its a pefect unit.
2.7 ohm is realy low, and the problem of using chipamps in paralell is a wee bit complicated. You can with ease destroy both amps, and the speakers them self.
If i was You, i would just find out what is the power handling of Your panasonic speakers.
It may well happen that You can get away with a simple amp. Prehaps the output voltgae (and therefor current) can be limited with a simple resistive voltgae divider at the input, this can protect Your amp from overloading accidently.
Can You post some -any- information about the speaker unit it self?
Old 16th April 2011, 09:09 AM   #5
I already pushed 22w (full range frequency) and it held up,just too much distortion.The magnet is 3" diameter and 0.4".There is nothing else printed on the magnet apart from the impedance.The original amp was a 6.5wpc at 3 ohm 10% thd.Despite the high thd,my dad swears the boombox is the best music system he has ever heard!
[/QUOTE]
Old 16th April 2011, 11:17 AM   #6
Default Here is the App for your chip in Bridgemode
It's a dual Power amplifier
and if you bridge it and heat sink it real good
and an use 2 appropriate output filters
Rl
.6uH in parallel with 10 OHms
it will work with work fine with your 2.whatever ohm load
Old 16th April 2011, 06:06 PM   #7
chip in Bridgemode
There is a big difference between 'bridged' and 'paralleled' amps.
Old 16th April 2011, 06:27 PM   #8
OK
your chip is a dual amp
to get the most out of a single dual you should Bridge
to Parallel I would use real low value summing resistors
.1 ohm high wattage
the resistors will dissipate off any differences
Old 16th April 2011, 08:08 PM   #9
You really need to use an lm3886
68watts
real clean
Old 16th April 2011, 08:23 PM   #10
SEMICONDUCTOR KIA6210AH - Electronix Online - Computer and Electronic Parts and Supplies
under 4 dollars
this is the chip inside altec lansing computer subs
I have one here it rocks
I pulled the caps out of the active LP filter
"that easy" converted it to a full range application
it was a 7 dollar thrift \ goodwill store score !
Series or Paralleled... JohnnyPraze Multi-Way 0 16th October 2010 10:31 PM
DAC 1955 paralleled fabiodord Digital Source 9 25th September 2008 10:20 PM
paralleled rectifiers for +/-v ? snkby Parts 4 23rd May 2006 03:24 PM
3 paralleled opa541's odysseybmx414 Chip Amps 1 11th May 2005 01:37 PM
Paralleled Toroids? theAnonymous1 Solid State 5 19th July 2004 02:40 AM
Page generated in 0.13302 seconds (71.17% PHP - 28.83% MySQL) with 11 queries
