| Chip Amps Amplifiers based on integrated circuits |
what is the typical current draw on a gainclone? im asking because ive been towing with making battery powered monoblocks. it would be cost effective for around 30 AH worth of batteries or so.
#2 |
Banned
What chip, what voltage rails, what impedence speakers, what.. umm... something else.. lol hmmm ah.. who knows.. lol
#3 | |
On Hiatus
So the current drawn is not very much. Consumption increases the higher volume you play. And of course the more music you play. At idle it could be max 0.1-0.2A or like that for a stereo. For high volume, my guess is around 1-2 Ampere, for stereo. Depends a little on how sensitive your Loudspeaker are. You know SPL/1 watt input. Measured in dB. SPL Sound Pressure Level at 1 watt input (8 ohm) halojoy - would think that covers the basics
#4 | |
Banned
Am I spending too much money on 400VA toroids? Halojoy, what do you call high volumes? Remember, this is a power op-amp. No miracles (anyway, I don't believe them Anyway, cowanrg, make a search on this forum and you'll find the information you need. |
#5 |
On Hiatus
dear carlosfm
1A per amp is an AVERAGE output of 4 Watt in 8 ohms = +6dB this means an AVERAGE Sound pressure level of 88+6 = 94 dB if Speakers have sensitivity 88dB (my have mostly 92-95) 94 dB is an awful lot of volume in a normal living room. you might not believe this, but there are Tube guys who lives happily with amps of no more than 5-8W MAXIMUM output. And what about JLH 10 W class A amp? One the most famous DIY amps in this world. Okay, IF you have very large room and IF you have very low sensitivity in LSP and IF you have very low average impedance LSP, say 3-4 Ohm IF you listen at full volume all day long I can agree on the average Ampere Consumption would be twice my first given number; 2 Amp/stereo Of course you have not waisted your money on your high spec power supply - an amp gets no better than what the supply allows it to In this case the guy wants to know how long his batteries would expectedly last before being halfempty 30 AH rated should not be discharged no more than 50% give us: 16AH/average Ampere=Hours of playing/per day (I assume we charge during nighttime/work) In my first case 16/2 gives 8 hours of total playing time worst case 16/4 Ampere gives 4 hours I myself have Carbatteries rated 60AH, would give me at least 30/4 ampere = 7.5 hours playing time That is totally sufficient. no one listens to music on max volume like 7 hours a day. For class A amplifiers, it is easier to calculate drawn current, it is constant. But class B is more effective, and dependent of musical power drawn. Remember that music power (the power consumed in class B) is a lot lower than RMS power. That is why we see those high numbers sometimes in advertising. halojoy - knows nothing about which is best gainclone but has a hunch on matematics, hopefully |
#6 |
Banned
Halojoy,
Don't get me wrong. Not everyone has 92-95db speakers. And some of the best speakers need current to play at they best. My Epos speakers are 86~87db, you need a good amp to drive them and my GC drives them very well. But I woudn't use a 2A transformer. What I have is a 2x24V / 8A toroid. You didn't understand me, I wasn't talking about power. I think that current delivery is much more important than power. And 100 watts RMS is just the double of 10 watts RMS in terms of power, not 10x more. I could live very well with a 20w amp with a good current delivery. After all, you normally listen below 1 watt. But 1 watt on a good amp is not like 1 watt on a bad one. Even at very low volumes I can hear my Epos sing like they never had, and all the dynamics is there. It's good to listen to music at night. Impossible to do with the Nad amp I had, which had around the same power as my GC. And BTW, I think that the PSU is the most important part of almost avery device, and amps more still. Make compromises here and you're ruining everything. |
#7 |
hi carlos,
there is nothing like voltage if you have speakers with low efficiency.....many watts are needed, and if they are a difficult load too then you need both voltage and amps....... |
#8 |
sounds good. all i wanted was a general estimate. i dont build things mated to any speaker, or to any particular volume level either. ~2 amps for stereo will work well. just toying with ideas of course.
it would be about the same price to do 30AH of power for monos than doing a couple nice toroidals... |
#9 |
The LM3886 has an idle 50-80mA and therfore is making som heat, not mutch but inoff to be konsidered. +/-35v gives 60mA*35 *2 = 4.2w as a typical value.
#10 |
i think its more useable to know how much it draws when playing loud - with difficult load.
as i recall, its internal current limit is 5 amps..... i would dimension the amplifier from that...... |
| calculating total current draw | woodturner-fran | Tubes / Valves | 3 | 9th March 2008 11:11 AM |
| current draw of a chipamp | jarthel | Chip Amps | 2 | 13th July 2007 11:45 AM |
| Current rating and tube current draw | cbutterworth | Tubes / Valves | 1 | 13th October 2006 04:42 AM |
| Min. current draw for choke input? | Klimon | Tubes / Valves | 14 | 14th November 2005 11:24 PM |
| Opamp current draw | 5th element | Solid State | 2 | 21st July 2003 12:11 AM |
| Page generated in 0.15774 seconds (68.32% PHP - 31.68% MySQL) with 10 queries |
