| Chip Amps Amplifiers based on integrated circuits |
Banned
GETTING SOME EXTRA POWER BY CONVERTING MICRO WIRES #32,30,28 GAGE IN TO #8 GAGE WIRE.
AVOGADRO CONSTANT IS RIGHT. SEE WIKIPEDIA HIT FOR AVOGADRO CONSTANT. SEE CONSTANT OR FUNCTION OF K CONSTANT AS DOMAIN. SEE ELECTRON MASS MEASUREMENT. AVOGADRO CONSTANT NA 6.O22 141 79 30 TIMES X10 RAISED TO 23RD POWER mol RAISED TO -1. CIRCUIT BOARDS FOR LM 4702 FOR LOW DISTORTION? WHY NOT HARD WIRE WITH #8 COPPER TWISTED STRANDED WIRE? #8 WIRE SIGNIFICANTLY RAISES VOLTAGE AND MICRO AMPS AND TOTAL POWER IN WATTS. USE OLD FASHION TUBE WIRING METHOD IN #8 WIRE FOR LM4702 CHIP AMP. C BOARD COPPER TRAILS COLLECT NOISE AND REDUCE SPEED OF TRANSMISSION OF ELECTRONS. USE OLD FASHION TRS 1/4 INCH CONNECTORS AND TRIPLE CONTACT STEREO PLUG CREATED IN 1909 SEE WIKIPEDIA FOR TRS PLUG JACK HISTORY. USE CONVERTED TRS 1/4 INCH JACK PLUG INTO MODERN MINI JACK PLUG CONTACTS ON HEADPHONES. #8 THICK WIRE SCOTCH TAPE TO MICRO WIRE AND THEN HEAT SHRINK THE TOP OF THE SCOTCH TAPE #8 REAL POWER WIRE NOW INTERFACED TO HARD TO WORK WITH MICRO GAGE WIRES. NO SOLDERING ON MICRO GAGE WIRING. YES SOLDERING ON #8 WIRE COPPER TWISTED STRANDED. AVOGADRO WAS RIGHT. MICRO WIRE AND CHEAP CIR BOARD TRACKS ARE NOT THICK ENOUGH TO MAXIMIZE VOLTS AND AMPS AND POWER AND CURRENT FLOW AND ELECTRONS IN COPPER PER mol. SLOW DOWN SPEED OF ELECTRON TRANSFER BOTH IN LINEAR CALCULATIONS AND STO-CAS-TIC RANDOM QUANTUM CALULATIONS. THANKS MARK ST. DENIS LAUGHLIN NV 89029 PS HI JACKINNJ -- EXPECT TO GET YOUR DIY-TECH PARTS INTO LAUGHLIN NV THIS WEEK WITHIN 7 DAYS MAX.
Last edited by Mark St. Denis; 12th April 2011 at 09:04 AM. Reason: JACK IN NJ IS EXPERT LIKE NELSON PASS SO TRY TO KEEP IDEA STRAIGHTKxyz |
#2 |
Banned
I WILL CHANGE HORSE JACKLE PRIEST FROM ANCIENT EGYPTION BOOK OF THE DEAD INTO MORE MODERN SPECTRUM ANAYLSIS AVATAR NEXT WEEK WHEN I GET THE EXTRA TIME.
Mark St. Denis Last edited by Mark St. Denis; 12th April 2011 at 09:13 AM. Reason: no patch for legacy qwerty keyboard slows down typing and mixes up full ASCI set characters complexity |
#3 |
Banned
Search = goldmine!
http://www.diyaudio.com/forums/showt...854#post750854 If you are interested in getting a prototype board to help those investigations along, there is even a group buy for some boards active! http://www.diyaudio.com/forums/showt...ost898724:eek: |
#4 |
Banned
I'm running a bias test on the LM4702 and Sanken STD03N STD03P:
Click the image to open in full size. The LM4702 itself chews up about 23mA. Here's a chart of idle current vs time: Click the image to open in full size. Report Post Reply With Quote |
#5 |
Banned
#6 |
Banned
#7 |
Sometimes a square peg fits a round hole just fine
what the hell are you, some kind of bot? or are you just insane?
THE ALL CAPS THING IS VERY ANNOYING TO READ!!! |
#8 |
sorry, bad day, my apologies for rudeness, but really this looks like junk mail to me and if not its very hard to read this assault of what 6 posts in a day. it may well be a good design even, but its not the best way to get my attention (i'll only speak for myself here)
#9 |
Banned
I WAS JUST TAKLING TO MY OLD LITTLE FRIEND MENTOR JACK IN NJ WHO SELL AUDIO PARTS AT HIS WEB SITE WWW.DIY-TECH-COM.
JACK IN NEW JJ WORED OR WORKS OR ASSOCIATES OUT OF PRINSTON UNIVERSITY AUDIO LAB. I THINK BUT NOT SURE - JACK IN NJ IS A PERSONAL FRIEND WITH THE FAMOUS NELSON PASS. WE ARE PHD TYPE OLD GUYS. NOT YOUNG NEW CHIP AM GUYS. DOES THIS POST SOLVE ANY CONFUSION ABOUT SPAM AND JUNK MAIL? TRY BUYING PARTS FROM WWW.DIY-TECH.COM. JACK IN NEW JERSEY IS ALSO A LEADER IN THE OFFICIAL NJ AUDIO CLUB. I AM OLD MANY AGE 56. STARTED MAKING AMPLIFIERS IN 1960 S. FIRST SOLIDER OF AMP CIRCUIT WAS IN 1965 AT AGE 10 YEARS OLD. THERE IS NO FOOL LIKE AN OLD FOOL CHECK OUT MY SITE AT COMPLEXTINYMACHINES.COM - Home. START UP SITE -- TO BUY TO COMPLETE SITE BECAUSE OF OTHER WORKING AT JOBS BY MULTIPLE HATS BOTH TRADE AND PROFESSIONAL HATS. I TRY TO USE THE KIIS SYSTEM -- KISS KEEP IT SIMPLE STUPID. HI AND BYE. MARK ![]() HOWARD HUGH SCHOOL OF ENGINES LAS VEGAS NV DEPARTMENT OF COMPUTER SCIENCE LAUGHLIN NEVADA EXTENDED RURAL CLASS NOW WORKING ON SPECTRUM ANAYL IN C++ AND SCRIP LINO SAMPLE SPACE BY POWER OF 2 TABLE 256 NEXT 1028 FOR DUAL CHANNEL PROTO TYPE INDEPENDENT RE - SEARCH AT POST GRAD SCHOOL............................................ .... HI BY WHAT EVER YOUR NAME WAS. Last edited by Mark St. Denis; 12th April 2011 at 07:22 PM. Reason: NEW AMP CHILD WANT TO BE SENIOR MODERATOR OF CHIP AMPS PROBABLY DOES NOT EVEN HAVE BS IN ELECTRONICS ENGINES. |
#10 |
Banned
I EXPECT AS USUAL FOR YOUR HIGH TECH MIND TO SEND ME PARTS FROM WWW.DIY-TECH.COM IN NEXT 7 DAYS TODAY BEING 04-12-2001 APPROX. 11 30 AM PDT USA PACIFIC OCEAN TIME LOS ANGLES AND LAS VEGAS TIME.
THANK YOU AGAIN FOR GIVING MY LTTLE BRAIN THE TIME OF DAY 5 YEARS AGO ON CHIP AMP LM4702. I FINALLY BOUGHT SOL GUN-IRON. MARK LAUGHLIN NV 89029
| Tech-DIY.com: Legitimate seller? | droneprime | Parts | 4 | 22nd November 2010 07:24 PM |
| Crown Com-Tech 210 Power Amplifier Crown Com-Tech 210 | tyler477 | Solid State | 1 | 31st October 2008 04:24 AM |
| tech-diy LM4780 board questions | Original Burnedfingers | Chip Amps | 1 | 13th January 2007 02:06 PM |
| Page generated in 0.12981 seconds (83.56% PHP - 16.44% MySQL) with 10 queries |
