diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   Tangent AMP-30 amp : which chip ? (http://www.diyaudio.com/forums/chip-amps/186459-tangent-amp-30-amp-chip.html)
coresta 5th April 2011 03:55 PM
Hi ,
A friend of mine just purchased this black box for cheap .... Amazing sound for his desk ! Since, I've tried the TDA2030 and have been astonished by performance of these 2,25 euros chips ... So What's inside the AMP30 ?!
Not a T-amp , an LM ? a TDA ? cheers !
Pierre
Leglandu 6th April 2011 12:27 AM
Class D ?
Hi coresta, yes, same question about this cheap (99 Euros - it was 200 Euros 2 years ago) and very small amp :
Amplificateur TANGENT AMP-30 NOIR - AMP30
Tangent - AMP-30 (Ampster) Micro amplifier
A review there :
Tangent AMP-30 review from the experts at whathifi.com
coresta 6th April 2011 08:59 AM
Bonjour Leglandu :-))
Sidérant ce bidule , tout comme les TDA2030 ...une photo de dessus semble faire état d'un TDA , dans le Tangent, mais comme l'appareil de mon ami est sous garantie, je me vois mal lui demander d'y zyeuter un coup dedans ...
Tu l'as écouté aussi ?
DJDestiny 6th April 2011 09:34 AM
Unless it was a TDA2030A @ 22v ,
Anyway , that's beyond the typical (minimum) specs of TDA2030A
Oddly there's a 5v USB Input which i have no clue what for .
http://www.datasheetcatalog.org/data...onics/1459.pdf
But truth to be told , the TDA2030A sounds good , if you use average components , those kits come with terrible components .
Seems like a different kind of transistor in the package , the harmonic distortion climbs up sharply @ 10 - 30W ( from 0.03% to 1% @ 32V @ 4 ohms )
The higher distortions come from third order which can't really be heard .
Distortion : 0.08% @ 14W @ 4ohms ( i wonder if that's the specs of the tangy )
Leglandu 6th April 2011 01:51 PM
The CSI way...
Originally Posted by coresta (http://www.diyaudio.com/forums/showthread.php?p=2529240#post2529240)
... Tu l'as écouté aussi ?
Nope, I did not listen to this amp already...
Any possibility to see something thru the ventilation grid of the top ?
By pushing inside (remove power cord before) a LED and a small mirror of dentist ? :)
jean-paul 6th April 2011 02:04 PM
Hi, I already modded one of these months ago. It is a linear amp and it has 2 x 4700 uF 25V power caps of so-so quality just like all the other electrolytic caps. The chips used are 2 x TDA2052 and 3 x chinese NE5532. Very heavy toroid and below average PCB quality. The holes are metallized but they immediately come off when you use a desoldering tool so you might need to rework the PCB when modding. It is a fragile amp. The designers had a hard time to squeeze such a big toroid in such a small casing. The casing is mostly made of aluminium AFAIK.
I changed the power caps to Pana FC 3300/25 (4700/25 is too large) and all the other electrolytics to the same values in Pana FC. The opamps were changed to LME49860.
Now it is a very good sounding and fast amp that astonished some of my audio friends. I am ready with it and it will go to one of those audio friends. It is still at home so if you have any questions please ask them.
Beware, the design is OK but the built quality is very cheap (except for the transformer) and PCB tracks peel off while you are looking at them. So risky business to work on them but rewarding when you succeed. In standard form they're OK but not spectacular mainly because of the opamps as they're some chinese NE5532 clone type.
After removing the top cover and PCB I drilled a large hole near the rectifier as there is a hot spot over there because lack of airflow. Oh and please be careful with the speaker cables as they are glued to the PCB but tend to break after you swing the PCB upside down a few times.
DJDestiny 6th April 2011 02:52 PM
Originally Posted by jean-paul (http://www.diyaudio.com/forums/showthread.php?p=2529406#post2529406)
I see , their pcb quality is below kit quality .
Where did the power amp chip come from ?
The power amp chip looks inferior to the TDA2030 because of the distortion figures , it's pretty violent .
Just that the power output is higher .
jean-paul 6th April 2011 03:03 PM
The ST made TDA2052 chips are fed by a heavy 2 x 15 V toroid and so performance is limited to 2 x 20 W. It sounds very good with the mods whatever the datasheets may say. Distortion figures are just very small in differences and AFAIK they're specified at the max. power the chip can deliver. Output current of TDA2052 is 6 A max. and TDA2030 is 3,5 A max. It would be unlogical if the distortion figures would not differ with these largely different currents.
TDA2030 is also from another era... TDA2052 is a modern very good sounding chip and it would be strange if it did not sound and measure better that TDA2030. I was very surprised when I heard the amp after the mods. In fact I still have the amp connected as I like it a lot. better than my other amps I have now. For just a moment I thought of designing a replacement PCB of better quality to fit in the Amp-30. No time for that unfortunately.
And this wisdom is not from paper but from spending several hours modding and listening to the actual amp and not from a web page ;)
The USB output is for connecting cell phone battery chargers and it is fed by a separate 12 V winding. The amp also features a subwoofer output.
Yes gentlemen, this is an amp for the Ipod/cell phone/MP3 generation. I only recommend it to people that are able to work fast/tidy and are able to repair damage that will be done. In standard form it is not that special.
DJDestiny 6th April 2011 03:09 PM
Originally Posted by jean-paul (http://www.diyaudio.com/forums/showthread.php?p=2529450#post2529450)
The chips are fed by a 2 x 15 V toroid and so performance is limited to 2 x 20 W. It sounds very good with the mods whatever the datasheets may say. Distortion figures are just very small in differences. Output current of TDA2052 is 6 A max. and TDA2030 is 3,5 A max.
Woah dude , you make the 2052 sound like they were from the era's where 110db woofers were common .
Toroids make sense , their minimum size is , yes , larger then a EI's minimum size , but hey , at least they placed toroids .
so how many VA were the toroids stuffed in ?
jean-paul 6th April 2011 03:24 PM
Don't know where you are pointing at but I actually have the amp and I also never heard a TDA2030 sound up to the standard I like. TDA2030 was designed and made in my youth and the TDA2052 is pretty recent. It can deliver enough current to my speakers which is not a a problem as they've incorporated a heavy toroid that can deliver that current. More luck than wisdom I guess but it works out very good. I just wish I could stuff so much parts in such a small case.
All I know is that the Amp-30 in this form beats several other amps I have. It is a pity that they've been costcutting in a lot of areas. It is a cheap crate made a bit too cheap with some very nice aspects to generate profit by a large margin. I even mailed Tangent that this amp could be a winner when made with some better materials worth 15 to 20 Euro.
Copyright ©1999-2017 diyAudio
