Tangent AMP-30 amp : which chip ?
Old 6th April 2011, 04:21 PM   #11
Leglandu is offline Leglandu  France
Many thanks jean-paul !
I find interesting the "Multiway Application Circuit" with PLLXO's (Figure 18 - page 10/14) in the TDA2052 Datasheet.pdf... certainly the Sub-out of the AMP-30 uses a part of this schématics.
Just a question : when you switched from NE5532's to LME49860's in your mod, had you to change some other parts or just it was totally compatible ?
Old 6th April 2011, 04:30 PM   #12
coresta is offline coresta  France
coresta's Avatar
Pay attention guys, a PLLXO is working on it's idle frequencies only IF the source is low Z !
Old 6th April 2011, 04:32 PM   #13
coresta's Avatar
Originally Posted by jean-paul View Post
Don't know where you are pointing at but I actually have the amp and I also never heard a TDA2030 sound up to the standard I like. TDA2030 was designed and made in my youth and the TDA2052 is pretty recent. It can deliver enough current to my speakers which is not a a problem as they've incorporated a heavy toroid that can deliver that current. More luck than wisdom I guess but it works out very good. I just wish I could stuff so much parts in such a small case.
All I know is that the Amp-30 in this form beats several other amps I have. It is a pity that they've been costcutting in a lot of areas. It is a cheap crate made a bit too cheap with some very nice aspects to generate profit by a large margin. I even mailed Tangent that this amp could be a winner when made with some better materials worth 15 to 20 Euro.
Jean Paul : Try it on 500watts rated regulated PSU , wired on CuAg , without any printed circuit
Old 6th April 2011, 04:38 PM   #14
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Why ? I like tidy designed PCB's with short as possible tracks and not RF attracting rats nests
It's only audio. Member of the non modular PCB design committee
Old 6th April 2011, 06:05 PM   #15
coresta's Avatar
because 25um copperlayer doesn't stand the inrush current a stranded silver wire can afford ... difference is the sound
Old 6th April 2011, 07:06 PM   #16
jean-paul's Avatar
Hi, I still have solid silver wire but I don't use it anymore despite that it should be better in some aspects. When you use silver you should use it in the entire chain. Copper and silver don't mix well sonically (thermocouple effect ?). So I went back to copper. Back to the subject please, as an ex-mod I would have encouraged us now to open another thread.
Old 7th April 2011, 08:58 AM   #17
DJDestiny is online now DJDestiny  Singapore
That's cause i was confused , you said that TDA2052 came from another era and i thought it was in the past
Still , you didn't tell me the toroid VA
Old 7th April 2011, 09:19 AM   #18
jean-paul's Avatar
TDA2030 is from another era = it is from the past. English is not my mother language but I think I expressed myself well.
The toroid does not mention VA rating but I guesstimate it to be at least 2 x 5 A. It only mentions 2 x 15 V and 1 x 12 V ( for the USB charging circuit).
Old 8th April 2011, 05:28 AM   #19
15V , 5A sounds slightly overkill for 20W ...
I usually use 12v 3A for 15W
Tangent AMP-30 amp : which chip ?Hide this!Advertise here!
Suitable woof & tweet for CV Full Range chip amp? lunchmoney Chip Amps 3 20th March 2011 06:00 PM
Chip Amp LM3886 stereo kit - built & ready to go cdoggy81 Swap Meet 8 24th February 2009 08:26 PM
Repair/replace 30-year old B&W DM6 woofer? jacques54 Multi-Way 7 20th December 2005 08:31 PM
Who has tried a current boosted op-amp (with a transistor) as a chip-amp buffer? sardonx Chip Amps 18 19th March 2005 12:23 PM
