Old 3rd April 2011, 09:56 AM   #1
Default Audio Chirp/Squeal
I have a Rockford P10002. Why does it chirp/squeal right at final shutdown.Other than that amp runs fine.
Old 4th April 2011, 11:34 AM   #2
Mooly's Avatar
Design fault maybe ?
Many amps can behave unpredictably as the rails collapse, and if it causes any noise in the speaker then imo the design is incomplete as an amp should be totally silent on power up and power down. It's an age old problem. Does it do it in isolation... with just speakers and the supply and with no inputs connected.
A simulation free zone. Design it, build it, test it.
Old 4th April 2011, 12:00 PM   #3
wwenze is offline wwenze  Singapore
It's an age old problem, so what are the possible causes? My DAC does that when shut down after running for hours but not if it has only run for a short time.
Old 4th April 2011, 12:24 PM   #4
Mooly's Avatar
The circuit design itself is the cause. It doesn't mean there is a problem, just that it behaves unpredictably as the rails collapse. There can even be a "race hazard" situation where multiple rails collapse at different rates... countless reasons really. There is no single fix or cure. There are examples of commercial amps that have had time constants changed to try and prevent such problems after customers complained... but the real answer is the design should be complete such that this either doesn't happen or is muted.
A DAC should have muting that operates within a few milliseconds of power down to prevent noises. I can think of some transistor radios that have done this, certainly several TV audio output stages over the years.
Old 9th April 2011, 07:14 AM   #5
Thanks for the replies, As I was wiggling some wires around I found that my remote wire was loose. Now it shuts down without any noise.
Luxman M120 distortion and squeal nac134 Solid State 0 30th November 2010 11:48 AM
Preamp Squeal neddyboy Tubes / Valves 14 25th October 2010 05:54 PM
Peavey Classic 30 - Squeal peaveyboy Tubes / Valves 4 11th February 2010 06:29 PM
Noisy Squeal from SE amp sonata149 Tubes / Valves 10 1st April 2008 08:37 PM
squeal in amplifier n0plb Tubes / Valves 5 5th July 2005 11:16 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
