Old 3rd April 2011, 06:37 AM   #1
Havoxx is offline Havoxx  United States
Default Trying to make a small sub out of a chipamp?
Hey all, I was scouring the internet for information, but is it possible to make a chipamp power a small PC sub? Nothing too extensive, and doesn't have to be too powerful, just enough to give a well, nice bass to PC music, I don't have too much money, and I have worked with an LM386 before, and I do find it quite fun, I was curious if anyone knows how I would go about making a PC sub out of a IC chip, and which one would work best. Thank you !
-Oscar
Old 3rd April 2011, 06:41 AM   #2
frugal-phile(tm)
planet10's Avatar
That will certainly work. Most store-bought PC subs (at least the ones i've pulled apart) are chip amps.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd April 2011, 07:15 AM   #3
sofaspud's Avatar
Oscar, since you're on a budget I suggest searching the web for a good deal on a driver. Once you've got a driver, then you can focus in on the proper enclosure and chipamp, and merging it with your current setup.
There's loads of information & support for the LM1875 chip. With just a modest power supply it will put out ten to twenty watts. I only mention it as a starting point. I don't really know what your design goals are other than your generalized statements.
Old 3rd April 2011, 04:21 PM   #4
I actually have an old samsung subwoofer out of a home stereo system that is rated at 100w, and it sounded great when I used it, but the amp itself was a display model and went nuts after a few weeks. I don't know the exact specs of it, I just know it's 100w and it's a 6" driver. I did check out the LM1875, and it looks like it would work quite well, not to mention it looks pretty simple to wire.
Now as far as a power supply, can I use a wall-wart and modify it, or should I make my own transformer for it?
Old 3rd April 2011, 05:23 PM   #5
sofaspud's Avatar
You have the driver/enclosure, you're just looking to replace the old amp?
No, a wall-wart probably won't do. Maybe, just maybe, a surplus switchmode supply will work. Otherwise you'll need a transformer.
Old 3rd April 2011, 07:37 PM   #6
Yea pretty much, I'm looking to make an amp for my PC, since I have all the other speakers working just fine, I'm just missing one for the subwoofer channel. It's just a driver, and the enclosure as you said, there is no amp/power to it, it's one of those that was powered by the headunit
Old 3rd April 2011, 08:30 PM   #7
sofaspud's Avatar
So you have a subwoofer-out signal. All you need is an amplifier and power supply. Yeah, the LM1875 would do. It's a little bit "up-the-ladder" from a LM386 but nothing you can't handle. I'd check the subwoofer forum for info on using a switchmode supply; I have no firsthand experience with it but see it as a suitable possibility. There may be something I'm overlooking though. Something like 20 volts at 5 amps is where I'd be looking for a power supply.
Old 3rd April 2011, 09:02 PM   #8
Alright, I will check out what I need and make myself a little parts list, I do appreciate the help, it's nice to have someone that at least knows a bit more than me lol.
Old 31st July 2011, 04:26 AM   #9
You can try TDA8947J
Old 1st August 2011, 08:42 AM   #10
sasmit is offline sasmit  India
Send a message via Yahoo to sasmit
Finding a good driver for a small sub is really tough. I would suggest the same thing, find a driver and decide on the type of enclosure first before you decide on a chip.
can i make a ported box for a small speaker? scampo77 Car Audio 6 27th October 2009 10:02 AM
How small can I make a case for a LM3875 kit? m0b1liz3 Chip Amps 9 3rd July 2008 11:10 PM
How to Make Small Cube Speakers Xyberz Multi-Way 61 9th January 2005 09:54 PM
new here -- wanna make my first small amp zx3chris Solid State 11 31st October 2002 09:48 PM
Page generated in 0.10476 seconds (76.47% PHP - 23.53% MySQL) with 10 queries
