| Chip Amps Amplifiers based on integrated circuits |
#11 |
Yes that will work well , it also has a dual primary so you will have to wire the primaries in Paralell and because it has a dual secondary and wire it in series and use the connecting point between the secondaries as your ground ....
hopefully your transformer will have instructions on how to do this , if not post back and someone will help you .... Cheers PS: you also going to need a 6v-0v-6v transformer for your preamp , maybe you can find a transformer that is 6v-0v-6v and 35v-0v-35v so you don"t have to buy 2 seperate ones .... |
#12 | |
It seems like you have drawn a conclusion on transformer power based on a completely erroneous efficiency statement that is simply untrue. A 125W amplifier will run well from a 125VA to 250VA transformer. Two channels will run well from a 250VA to 500VA transformer. These 125W amplifiers will also work with transformer ratings outside that restricted range, only less well. Above the 500VA the transformer provides less performance value for the monetary value expended. Below 125VA the performance deteriorates much more than what could be saved in transformer cost. One has to apply a cost benefit analysis. How much performance do I need? How much can I afford to spend? Do not believe a fixed figure of 250VA for a 125W amplifier. Last edited by AndrewT; 6th April 2011 at 01:01 PM. |
#13 |
So if i have a 240 watt RMS amp. What will power it to its full potential?
And i also need help with a case, cause right now, im am not sure that with all the things i have, it will meet my budget. So anything cheap for a case, or a used or burned out amp case will work. -Thanks |
#14 |
That depends, is it class A, then a small nuclear substation is in order, class B 500VA is more than enough, and less is fine depending on the load and volume at which it is driven to. Class D, takes what it puts out and sips a little bit extra.
A 250VA transformer is more than enough for a stereo pair of LM3875 driven into 8R at 35VDC supply, and will only get mildly hot when driven hard. |
#15 |
Its class AB. So what will i need now? And there is two amps btw.
#16 |
I had a look at your amp, it says 2 x 120W at + and -50V. So I would at a minimum use a 500VA 2x35VAC transformer.... I'd certainly also use bigger heatsinks than the ones in the product shots...
#17 |
Bs1777..have you got a good power supply for your amplifier build?
#18 |
Read Audio Sector's, Chipamp.com, and Decibel Dungeon's sites for tons of basic info on building amps and power supplies. Lots of ideas and common practices as well as safety issues addressed. These sites were invalueble to me when I first got started in DIY Audio. Good luck!
#19 |
How did you hook up your wires for the power to VEE, VCC and GND? From what I've saw, I think that you need -50V / GND / +50V.
| Amp Design/what goes into building a great amp | fglabach | Solid State | 141 | 12th June 2009 05:17 PM |
| building EMG BQS system <>? | woodbuilder | Instruments and Amps | 0 | 16th May 2008 02:58 PM |
| Building ONO - looking for 2SK170 & 2SK389 | skseah | Pass Labs | 34 | 7th February 2005 10:19 PM |
