| Chip Amps Amplifiers based on integrated circuits |
The home theater system was given to me by a friend who said it did not work and was about to throw it all away. After the first inspection, I noticed the PCB was of very poor quality and had cracks, thus I decided to recycle the components that were good and build my own 5.1 amp to use with my computer.
I tried to simplify the design as much as I could as I am not looking for a HI-FI system, just something to listen to music and watch movies on my PC. I also tried to follow the original design as much as I could to avoid getting new parts. Currently I have a few doubts that I hope someone can help me with. 1-Not sure if the two fuses (F02 AND F03) go before the rectifier as drawn or actually need to be placed at the very end after the capacitors (C1 & C2). 2-After reading much about the subject in the forums, I am confused about grounding the 0V line to the metal chassis, as there wasn't such a connection in the original design and also working at 220V 50Hz with no ground connection, I am not sure what would happen or its even advisable. 3-As for the rest of the system (the actual amp) disregard the 12V rating on the caps, I just copied the design from the IC manufacturer and haven't calculated what I really might need to use. 4-Also any ideas on how to best split the signal on Amp3 (sub woofer and Center channels) would be appreciated. Again, any help, suggestion or comment is welcomed.
#2 |
The fuses are shown across the rail making a short circuit. The position is fine before the rectifier. I can't make out the chip in use TDA-something it looks like.
#3 | |
I am also a little concerned as when I started plugin the AC mains one by one, when I had two connected (+17V -0V) the toroidal started humming. As I was surprised by this, I took the multimeter and once I touched one of the mains, the capacitor and fuse blew. The Amp is a TDA7264, sorry I didn't realize the picture looked so small. I'll put it in PDF so one can zoom in. |
| A frugal recycled sub idea | Brisso57 | Subwoofers | 15 | 20th March 2008 08:31 PM |
| Decoding another recycled power trans | engels | Tubes / Valves | 5 | 15th November 2007 02:59 PM |
| My DIY recycled, retro, and really Neat-0 Gainclone box. | Spasticteapot | Chip Amps | 11 | 12th November 2006 11:43 PM |
| GC from recycled parts from PC Power Supplies | Mikett | Chip Amps | 3 | 18th April 2004 12:11 PM |
| Recycled crossover cap question | jag | Multi-Way | 1 | 24th January 2003 01:59 AM |
| Page generated in 0.11677 seconds (57.24% PHP - 42.76% MySQL) with 11 queries |
