| Chip Amps Amplifiers based on integrated circuits |
Okay I know how this sounds but what'd be the drawbacks/advantages to making a single 100W amp by paralleling 20 or so simple op-amp amplifier circuits?
#2 |
which opamps?
It would take a whole lot more than 20 regular dual opamp chips to get 100 watts. jer |
#3 |
Banned
#4 |
I looked thru the thread but I couldn't really find much about how the thing sounded. Did I miss that?
#5 |
Another way to do it is operate several credit cards in parallel and buy one of the big Apex chip amps.
Conrad
I used to be an audiophool like you but then I took an arrow to the knee. |
#6 |
For a 100w amp you would need something like a + & - 50v power supply. Opamps
that can operate at those voltages are hard to find and pretty darn expensive. |
#7 | |
Banned
w |
#8 |
#9 |
The highest common/cheap opamp voltage supply is 42V (=+-21Vdc).
This will allow maximum output voltage of ~ 18Vpk into a load. Now parallel sufficient opamps to deliver the peak current that a speaker could demand from 18Vpk transients. 8ohms could be ~220 30mA opamps giving an effective output power of ~ 20W into 8r0. Speakers seem to be a non starter. Medium or high impedance headphones would be a more suitable load. Oh, before you ask you could bridge your opamp amplifiers for ~80W into 8r0 but this would require ~ 900 opamps each capable of delivering undistorted 30mApk (not the short circuit limit)
regards Andrew T. Last edited by AndrewT; 1st April 2011 at 11:01 AM. |
#10 | |
load sharing will more than probably not going to be equal so you can run into -more or less- n-1 problems, where n is the number of opamps You need to use. Maybe if You need to, You might find a decent opamp that has enough current capacity and output voltage to paralell a quad opamp for a headphone. or drive a piezzo tweeter (whatever is benefical in that, but who em i to know.. realy) Actualy if You ask me, for those power levels it may not be usefull at all. You might be better of just adding output transistors on some high supply/output voltage opamp. Not a clever solution but who knows, might actualy work out well. |
| I tried the ebay MX50 DIY Kit, Class AB 100W+100W; Worked but problem. | Buckeye | Solid State | 48 | Yesterday 07:06 AM |
| Who has ever heard of RCA's HC1000 100W amp Hybrid Chip? | smartx21 | Chip Amps | 11 | 1st August 2011 08:02 AM |
| Massive P3000.1 massive DC offset | amc32 | Car Audio | 5 | 16th March 2011 05:40 PM |
| LM3886 PA100 100W Chip Amps Assembled! w/heatsink, Tested & Ready To Go! L00K :) | MartyM | Swap Meet | 0 | 19th November 2010 03:16 AM |
| Need help fo 100w+per channel stereo chip amp | mlaroche | Chip Amps | 14 | 12th December 2006 12:20 AM |
| Page generated in 0.10787 seconds (74.86% PHP - 25.14% MySQL) with 10 queries |
