| Chip Amps Amplifiers based on integrated circuits |
Hello to you all.
I have been looking to build an amp to replace the output of an old receiver and have looked at designs using 3886 etc put they all are in the +- 35volts range. Are there any similar chips using +- 60 volts. I am aware of the old STK0080 series but never found good reviews of them. Would prefer something more modern and of better sound quality but still simple like the gainclones. Thanks. |
#2 |
Apex precision power from cirrus logic has power opamps all the way up to -+200v.
However the are very pricey. jer |
#3 |
60 volt rails is an amp of a very high output power, why that voltage?
#4 |
Because that's the transformer in the receiver he wants to modify.
Tyler |
#5 |
Oh of course, my bad, i didnt read the question properly.
#6 |
I rebuilt a Parasound A23 using an LME49811 driver and an STD03N/STD03P output stage. The A23 main board was fried, but the +/-56~60 V supply was still good. So I reused the supply and built my own amp board.
See thread here: Yet Another LME49811 + STD03 Build Not quite as simple as the LM3886, but better performance and not that much more complexity. ~Tom |
#7 |
Thanks for your response as was stated the amp has a +- 60 volts supply and also the space is limited . So I need something compact and price is also an issue.
Thanks. I will check out the LM4702 designs. |
#8 |
I forget the exact size of my LME49811 board. 6x10 cm or so. Fairly compact. Not as compact as an LM3886, but close enough. I've seen people (panson_hk in particular) build modules that would fit on the back of a heat sink. That may be an option for you.
~Tom |
#9 |
You could use almost any chip amp in a single supply with one 60V rail. For example, the absolute max for the LM3886 is 84V, regardless of whether it's dual supply or single supply.
Tyler |
#10 |
A bridged LM3886 would be good with a 60volt supply.
Or better yet a BPA-200 using four LM3886's or two LM4780's. You could use one amplifier circuit per rail. jer P.S. A BPA-100 would probably be a better choice depending on the VA rating of your transformer. Last edited by geraldfryjr; 31st March 2011 at 10:32 PM. |
| DC heater voltage 6 volts or 12 volts? | speakerfritz | Tubes / Valves | 7 | 8th October 2010 03:59 PM |
| Yamaha M-60 power amp for sale (w/ impaired C-60 preamp) | rainzoneman | Swap Meet | 10 | 3rd December 2009 01:44 PM |
| power transformers 220 volts to 110 volts | garydmd | Chip Amps | 3 | 7th April 2007 02:52 PM |
| Gainclone is on 120 volts will it be fine at 220 volts? | Jimmy154 | Chip Amps | 7 | 29th June 2005 12:10 AM |
| Peavey Classic 60/60 bias mod advice | RIC | Tubes / Valves | 5 | 23rd March 2005 06:16 AM |
| Page generated in 0.09912 seconds (78.14% PHP - 21.86% MySQL) with 10 queries |
