Bridge construction - Page 4 - diyAudio
Old 6th August 2003, 09:21 PM   #31
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Default what ?
Originally posted by Peter Daniel
I also suspect, that although snubbers may improve certain aspects of performance, they screw up sonics in some other way.
I have repeatedly noticed a huge improvement in quality with just caps but that is with the caps directly across the secondarys. otherwise as andy says the caps are just providing a HF s/s path across the diodes
have you tried caps across the secondarys ?
I would be really suprised if you did not notice a big impovement.
I use 4.7uF on all my power amps - sounds outrageous in theory, but in practice, for me, it sounds amazing, much more refined and no trade offs that I have noticed
If you do not notice the difference I will have to conclude that we are living in different universe's with different laws of nature operating
chou
mike
Old 6th August 2003, 09:36 PM   #32
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
I didn't have a chance to try caps acros secondaries yet. Next time I'll try. I noticed big difference when I place the caps right after bridge, so I think I'll be able to hear them at secondaries as well
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 6th August 2003, 09:57 PM   #33
Jonclancy-
Thanks for the link. I like that layout. I think I will turn it inside out, tho, without the pcb. Lay them on their sides with pins in on the perfboard. Bend the pins down into the holes and solder the bridge.
Then I will heatsink each diode with something small, and since the tabs are all pointing out, I will have plenty of room.
As long as I have a little air circulation gap between the diodes and the perfboard, I should do fine.
I had the right to remain silent. I just didn't have the ability. (Comedian Ron White)
Old 6th August 2003, 10:07 PM   #34
Here's one of my more recent bridges in GC monoblock. One per rail Gainclone monoblocks
www.audiosector.com
Old 7th August 2003, 12:04 AM   #35
That is a nice design, Peter.
Are they heatsink'd (heatsunk?) or just mounted?
It would screw the bridge up if they were not insulated on a common heatsink, wouldn't it?
GnD
Old 7th August 2003, 12:24 AM   #36
they are heatsinked, but because the heat issue isn't that big here I used a piece of thin fiberglass strip for that purpose. If you have enough space this is probably the best way to wire a bridge: outside pins connected together for AC supply, the inside pins crossed connected for ground and DC supply. As you see, no snubbers this time
www.audiosector.com
Old 7th August 2003, 11:58 AM   #37
Have you guys tried the RC filter described as ideal in the article you quoted? The graphic with just the cap showed a pronounced lower-freq sine, for a long while after the no-snubber ringing would have ended. It is lower energy so it doesn't couple with other elements of your circuit, but if you make the cap a lot bigger than what was quoted you end up impinging on audio frequencies.
Old 7th August 2003, 01:26 PM   #38
I the real world I find it hard to see any ringing wether the cap is there or not. for me, the lower the frequency the better, the filter caps and chips supply rejection are far far more effective at low frequencies. subjectively the big cap sounds great.
it's worth trying...
mike
Reopening an unfinished debate: Dual bridge vs. Single Bridge xiphmont Chip Amps 15 26th February 2008 08:22 PM
half-bridge VS. full-bridge gearheadgene Class D 3 25th May 2007 09:49 PM
The difference of Push-pull,Half-bridge,Full-bridge digi01 Chip Amps 0 8th September 2006 03:10 AM
Whats the difference between full bridge and half-bridge SMPS ? skaara Class D 6 3rd February 2005 08:23 PM
Copyright ©1999-2017 diyAudio
