| Chip Amps Amplifiers based on integrated circuits |
Hi all,
I recently discovered this site and I'm very pleased. I just finished my first project, a cmoy based on the tangent tutorial, and I might be hooked ![]() For my next project I'm considering a dual mono amp to power small 8ohm monitor speakers (something in the ~20 watt range). I wonder if there are any powersupply alternatives than the bulky toroids? I'd like a smaller and more portable case. Are AC -> AC wallworts a possible alternative? Some sacrifice in sound would be ok. As form better toroidal (or suitable square ones), are there any recommendations for places to salvage suitable transformers? TVs, old radios, etc? Thanks and looking forward to continuing to learn from this site! |
#2 |
The usual recommendation for a transformer for a power amp is that VA should be one to two times the total maximum output power.
If you have chosen your transformer voltage to give 20W+20W output into your 8+8ohm speakers, then the smallest transformer I could recommend is a 40VA. This will impact on the sound quality of the amplifier, but it will work.
regards Andrew T. |
#3 |
People have sucessfully used Swithmode Power Supplies with good results. Perhaps a couple of old laptop power supplies could be what you are looking for? As Andrew rightly points out, ideally they would be able to provide at least the maximum continues output of the amp.
#4 |
Be careful the continuous output and transient output capabilities of the SMPS may not suit the very variable nature of the current demand of an audio amplifier.
regards Andrew T. |
#5 |
40 VA is suposedly the minimum, to be safe.
laptop charger i might not recomend, usualy SMPS has a turnon voltage spike , You may need to use a dummy load and a delayd relay to make things work in order. If You have a wall pulign adaptor You may give it a go, if You do not need to drive the amp to the max even less than 40 VA can do the trick. |
#6 |
Thanks for the feedback everyone!
My situation is that occasionally I need to use two small 8ohm monitor speakers. Playback quality does not have to be audiophile level (though higher quality is always nice) as it is used to play back unmixed/unmastered track captures during recording sessions. A friend has used a cheap berhinger headphone amp to drive them and the sound was acceptable. For portability sake, I'd like to fit a stereo amp (maybe BrianGT's LM1875) into a small as possible (reasonably) package and power it with a wallwart. Obviously, I'm pretty new to all of this, though I'm learning. Id also be fine with a normal powersupply using toroids or center tap transformers but the $50 price tag is more than I'd like. If I could find a source for one good transformer (free from a broken device) I'd live with the larger size. Any thoughts of the types of older devices I might be able to pull either a small transformer for lower volume listening or a larger transformer for higher output assuming I'm powering a LM1875 based amp like BrianGT or others? Thanks again. I love learning new things! |
#7 | |
14 - 24 VAC Adapters Thanks again! |
| TEA2025 alternatives | mikesnowdon | Chip Amps | 33 | 24th December 2011 10:58 PM |
| Tannoy alternatives | AuroraB | Multi-Way | 48 | 27th March 2011 05:52 PM |
| 6SL7 alternatives? | Cobra2 | Tubes / Valves | 19 | 10th September 2009 09:40 AM |
| alternatives to LF411 | AndrewT | Parts | 22 | 21st August 2006 08:02 AM |
| Any EL84 alternatives? | sardonx | Tubes / Valves | 20 | 22nd March 2006 06:36 AM |
| Page generated in 0.09825 seconds (70.43% PHP - 29.57% MySQL) with 10 queries |
