Old 18th March 2011, 07:55 PM   #1
maurycy is offline maurycy  United States
Default TDA2822 headphone amp - question about voltage
I have small amp built based on TDA2822 (schematic). Would it be better to run it on 2xAA or 1x9V? My headphones are AKG with 600 Ohms impedance. I am not really concerned on what would give me longer run time but more concerned what would be the correct voltage to run if used as headphone amp as it takes less time to charge AA than 9V.
Thanks.
Old 18th March 2011, 09:00 PM   #2
I would go for 9V battery.
2xAA reachrgeable will get you 2*1.2 volts, that is somewhere 2.4 volts.
and You need 3 volts minimum to get it going.
Even so, if the amp could manage to get that 3 volts as output, with a 600 ohm headphone it may not even be enough for anything.
0,015 watt, I em not a headphone user, but that seems a bit low for anything i might think of.
So i would go for the 9V solution.
Old 18th March 2011, 10:33 PM   #3
Send a message via Yahoo to Th3 uN1Qu3
If the 'phones were 32 ohms i would have used 3 AAAs. In any case not 2. For 600 ohms, 9v all the way. Be aware that the 2822 isn't stellar - it works and it's almost impossible to damage, but that's about it.
"Audio grade" components simply means that they failed at a more critical job.
Old 19th March 2011, 02:27 AM   #4
Thanks for replies. I will go with 9V battery then. In my case it is even better because I already have an enclosure with support for 9V battery. As to the performance of the 2822, I am not too concerned about it because it will be used to amplify signal of my electric guitar for some late night practice. No need for the hi-fi sound.
TDA2822 headphone amp - should I add volume pot? maurycy Chip Amps 2 17th February 2011 03:06 AM
Headphone amp circuit question. Artie Headphone Systems 5 15th April 2009 07:32 PM
low voltage headphone amp Dan2 Headphone Systems 30 1st December 2008 10:39 AM
Opinions on my low-voltage hybrid headphone amp (this time with the right file) JHawk24821 Headphone Systems 2 1st August 2004 04:49 PM
Page generated in 0.07631 seconds (78.05% PHP - 21.95% MySQL) with 10 queries
