PSU from a PC
The idea to build my own computer speaker/amp setup was spawned today at bestbuy when a person… (sad to say I don’t even know his name :dunno: , but he is called swirv on here… thanks to him telling me about this site)… anyways he started telling me about how he was the chief engineer at DEW Recording Studios and then went into details about his on building. He asked me about my skills etc... I basically told him I was pretty good with electronics… etc… He presented me with the challenge to build my own amp/speaker setup. So here I am now getting started and I have considered adapting a computer PSU. Please give me some pros and cons… Computer PSUs have 12v and 5v. I know you have to have some sort of a load(resistor) on the 5v side for the 12v to power. Well… now hopefully I will have some replies…
~Conrad
you can replace the rectifiers for the -12volts with one of simmilar rating as the +12 volts so that you can have 24volts out of a pc psu, you can even play around with pin1 inout of the tl494 pwm regualtor chip so that you can get up to 28volts or so without too much circuit modifications, then another psu and you can have a +/-28volts supply...fyi i am into pc psu repairs and modding...
Desktop SMPS supplies are typically optimized for high-power 5V output and relatively low 12V power.
I would instead recommend that you consider notebook power supplies (external) because they typically provide one output at significantly higher voltage. I have seen 18-20V (I believe Dell have fairly high voltages, possibly even higher than 20V, most others are about 18V as I recall).
Newer devices have about 65 or more watts. If one assumes 20V power supplies:
If you build a balanced amplifier, you only need one such unit. A balanced amp into 8 ohm speakers should yield 50W per channel, 4 times that into 4 ohm speakers but then the power supply will be holding you back of course. You will typically not be able to get up to these levels.
Also, if you find that outputs are truly isolated, you can use two units as a split supply, doubling available power to load, and still providing 50W per channel in a traditional stereo amplifier (both channels into 8 ohms.
Petter
i've pulled enough computer power supplies apart to know that it's unlikely you'll find a transformer/toroidal inside worth using for an amp
basically they typically have a bunch of different size transformers inside, so even tho a psu is rated at 300w for example, it WILL NOT deliver all that on one voltage line.
QUOTE]How are transformers in the computer PSUs? usable?[/QUOTE]
the +12/5volts and the -12/5volts are all taken from a single transformer inside the pc psu, an at psu will have a main chopper transformer and a small driver transformer feeding the bases of the transistor switches in a half bridge configuration., an atx psu will have another transformer to supply the 5volts standby voltage Vsb. It is the chopper transformer feeding the 5/12 volts rectifiers that we are after....
true again without modification, but still you can get qet least 24volts out of a pc psu by modding the -12volts rectifiers to have equal amp rating as that of the +12volt rails......[
