The Active Studio Speakers Project
Old 17th March 2011, 10:17 AM   #11
haelius is offline haelius  Portugal
ok im gonna reverse a bit... and gonna use the creative board without getting the chips off.... it has the 7372 and 8510j tied, so my only problem is gonna power it cause the transformer is 12V AC 3.9A (lost it), but theoretically, its just needed to chant after the rectifier bridge right, after the big capacitator 4700uF 25v?
i am gonna post the back of the PCB so u guys please help if u can
i need to power it using the PC power supply, and THE MOST IMPORTANT, i need to bypass the power volume, cause it powers on the board, and i dont have it..... can anyone help a bit?
Old 18th March 2011, 10:40 PM   #12
Arty is offline Arty
"ok im gonna reverse a bit" -> do not.
and take a good look arund, i bet if you do you find a more suitable psu than the pc psu.
Wallplug adapters, old radio / other junk you or someone who you know does not need, and so on. You can salvage the parts needed, if You are realy upto do some low cost DIY.
Who knows, You might even find good quality stuff.
(like.. I managed to salvage nice TL74 IC thisway.. And other usefull things such as 6300 uf caps, and many handfull of ceramic caps, safety fuse, switch, acceptible pots, a few 78xx regulators complete with circuitry and so on..)
At any case, doing it DIY is the fun way.
And in Your position i would say it will be a lot more easy than to "whack" your way to power that amplifier.
Old 19th March 2011, 09:55 PM   #13
R.I.P.
Hi Pmb,
thank goodness you are awake.
They know the formulae and they can't apply them !
regards Andrew T.
Old 8th June 2016, 08:05 AM   #14
BDAWG is offline BDAWG
Hello everybody!
I'd like to use the TDA8510J to power a 20W 4ohm driver. What would be different in this schematic?
http://1.bp.blogspot.com/-X5lqY0AE9A...it+diagram.png
I'm new to DIY electronics and any help would be much appreciated
Old 8th June 2016, 09:19 AM   #15
Originally Posted by BDAWG View Post
Hello everybody!
To be more precise:
  1. I would use a mono input signal from the subwoofer output of my amplifier. Would that be split to pins 15 and 17?
  2. Will I then leave pins 1, 3, 6, 8 and 9 untouched? Any others?
The simpler the better.
The Active Studio Speakers ProjectHide this!Advertise here!
FS : Studio One Pi Speakers aka Fred's EZ speakers Cacophonix Swap Meet 6 10th September 2007 10:56 PM
Design recommendations for active computer speakers via KX Project? mazeroth Multi-Way 0 3rd November 2005 03:45 AM
active studio monitors or ??? argonrepublic Multi-Way 3 17th June 2005 10:33 AM
Active studio monitor modifications argonrepublic Chip Amps 0 30th May 2005 10:59 PM
Active studio monitors Yoda Multi-Way 7 22nd December 2001 01:32 AM
