| Chip Amps Amplifiers based on integrated circuits |
does anyone know where can I find a PCB layout for LM4780 when using a switched power supply ?
#2 |
Is there any reason why you want an SMPS? I think an unregulated DC supply works just as well if not better under certain conditions.
#3 |
Passive Aggressive
I bought a couple Lambda supplies from Ebay about 3 years ago. They really sounded excellent driving my LM3886 which is of course half of a LM4780.
I am sorry but I dont know of any pcb layout specifically for switched but I also dont think you need a specific layout for switched. I am sure that I didnt need one. Your switched will need a Plus/Minus/Ground though. Make sure you dont buy one with just Plus and 0V. Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#4 |
http://www.national.com/ds/LM/LM4780.pdf
at page 7, Single Supply Application Circuit isn't this the schematic for an switched supply that has only + and 0v. I'm asking this because I already have a supply with this value, and I plan to use it. Thanks for your replies |
#5 |
A power supply is a power supply linear or switching.
As long as it meets the power requirments it is supposed to do. jer |
#6 |
What do you expect to be different in the amp's layout, when you use a different power supply?
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#7 |
as I said my power supply doesn't have +V, -V, and gnd, as I noticed most of the layouts are using. I only have +V and gnd.
In the datasheet the only schematic that has only +V and gnd is the one on page 7, as I said in my earlier post. Is that schematic OK, can I use it ? http://www.national.com/ds/LM/LM4780.pdf at page 7, Single Supply Application Circuit |
#8 |
Passive Aggressive
Make sure to read page 18 for single supply operation. Also, since this is how an amp in a car would have to operate I am betting there is an app note about how to implement it and I also bet that in the car audio section you will find folks who have done what you are talking about already.
Uriah
#9 |
what car
? I want to use it at home...
| Switched Power Supply Design Course | gala | Power Supplies | 1 | 21st January 2006 10:19 AM |
| PFC Switched-Mode Power Supply | N-Channel | Power Supplies | 57 | 13th June 2005 07:56 PM |
| Switched mode power supply | MMicke | Car Audio | 3 | 19th February 2005 10:42 AM |
| Switched power supply? | Johan_Ch | Tubes / Valves | 38 | 31st January 2004 11:53 AM |
| Switched Mode vs Linear Power Supply | royalmp2001 | Solid State | 4 | 12th July 2002 08:04 PM |
| Page generated in 0.09022 seconds (75.45% PHP - 24.55% MySQL) with 10 queries |
