Old 4th March 2011, 03:01 PM   #1
pra3718 is offline pra3718  India
Default EAS Controller revision A
Please help me for following points
1> Is it possible to replace 1n(c11) with 220pf (if not available)
2> When mid-bass disappears, then the phase is wrong, so I will have to switch to the opposite position. Once I achived proper phase, Should I remove the switch with wire link, Or I will need it for feature.
3> VR1 is for adjustable gain. Is there need to adjust always or Once I adjusted I can contole with volume pot. Even Can I remove VR1 and achive the proper gain setup with 22k(R10) resister.
4> Can I replace TL072 with NE5532 to keep all remaining components same.
5> Is it stricktly advised to use closed box with 12" driver ? Or I can use ported enclosure with 10" driver
Regards.
Old 4th March 2011, 03:51 PM   #2
what is EAS ?
regards Andrew T.
Old 5th March 2011, 09:35 AM   #3
P48 Sub-Woofer Controller (Rev-A)
Old 5th March 2011, 10:24 AM   #4
It is possible, but defeats the purpose of the capacitor.
When you move the woofer to a different position it may be necessary to adjust the phase again. Keep the switch.
Once adjusted you control the volume of the entire system with the volume pot.
You can replace R10+VR1 by an adjusted R10 once you found the right setting. If you change something in the setup, you may however need to readjust and then the potentiometer is more practical.
Yes, but you may get issues with DC offset. That won't hurt the following stage, if C5 is in place, but it may limit the output swing.
Read the article again and understand what you are building. The answer to your question is given in the section "Driver Selection and Hardware".
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 5th March 2011, 10:27 AM   #5
1.) c11 is the RF attenuator. Yes you can replace the 1nF with another value. This changes the F-3dB of the RF filter.
4.) the TL0xx series are FET input opamps. If you must replace them then use another audio FET input opamp.
5.) the EQ & Gain is designed to work with a sealed box speaker. See Linkwitz transform.
The EQ required for a vented speaker is completely different. See 6th order alignment.
regards Andrew T.
Old 5th March 2011, 10:42 AM   #6
Thank you, TL0XX is not available in my city. NE5532 is available.
Old 5th March 2011, 10:48 AM   #7
5532 is a BJT input opamp.
regards Andrew T.
Old 6th March 2011, 10:58 AM   #8
Everything is fine now. I want to know more about phase switch. Which is the right position for me inverting or non-inverting. I found adjusting gain moves driver's cone front/back.
I found full-range input sounds good then low signal feed. I never experienced TL0xx so I can not make difference to ne5532 but it is good controller.
Old 7th March 2011, 05:07 AM   #9
Sounds like extreme DC offset. Do you have C5 in place?
Old 8th March 2011, 09:31 AM   #10
I build exact same. Accept, 1n(c11) is replaced with 220pf. Yes I did not use 4.7uf B.P.(C5) and 100K(R14) because I thought, my power amp has input cap 2.2uf followed by 25k resister to ground (input-impedance resister)
Yes, I read this line in the article but did not find any big changes using phase.
Northcreek Okara Revision Question mevaniuck Multi-Way 3 2nd July 2006 07:15 AM
EAS subwoofer controller broblem romulo_rosil Solid State 3 15th March 2006 01:07 AM
elf/eas controller source masterp2 Multi-Way 2 24th June 2005 01:01 PM
EAS/ELF doubt rs1026 Chip Amps 8 9th November 2004 06:45 PM
Page generated in 0.12152 seconds (79.48% PHP - 20.52% MySQL) with 10 queries
