| Chip Amps Amplifiers based on integrated circuits |
i have problem here.
![]() i have stereo input and single chip TDA 7294, how to combine stereo input for my chip amp???? |
#2 |
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Or get another chip ......
#4 |
What's the source and what's the purpose. Usually can combine signals with a simple resistor matrix (each signal connects to a resistor which are joined together with another resistor to ground - the point where they come together is a mono signal. Drawback is if the first two resistors are too small - can affect the stereo separation (if it is still important) Second drawback would be lower signal level - but that is easy to adjust for. BTW, this is the most common method with most subwoofer amps. YMMV.
Steve |
| tda 7293 and tda 7294 help | sagarverma | Chip Amps | 84 | 19th May 2012 03:40 AM |
| TDA 7294 Use it or go LM3886 | benje | Chip Amps | 6 | 8th January 2005 07:45 PM |
| TDA 7294 PCB - need help :) please | Szaflik | Chip Amps | 3 | 17th December 2004 08:51 AM |
| TDA 7294 Subwoofer | abid_rehan | Chip Amps | 6 | 18th December 2003 03:36 PM |
| Page generated in 0.08857 seconds (63.51% PHP - 36.49% MySQL) with 10 queries |
