LM1875 vs LM3886
LM1875 vs LM3886
Old 28th May 2013, 05:47 AM   #51
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
If your definition of 'rich' is based on salary alone then most probably you're richer than me as I'm only in part-time paid employment at the moment
I still continue to maintain you're not very close to getting the best from your LM1875 with that PSU. But hey its your project
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 18th June 2013, 08:43 PM   #52
lsheng is offline lsheng  United States
Default I am not sure
Maybe discussed somewhere else, as in simulation I see 1V peak to peak ripple on a 10000uF cap with regular bridge rectifier when 1A is consumed(8W at 8Ohm speaker, 4w AT 4Ohm). 2200uF the ripple will be 4V. This is equivalent power of 0.25W at 8Ohm, with superior PSRR it maybe still ok. But you supply will effective drop 4V to provide unclipped sound. I think this is bad. If you consider cross modulation, it is even worse, in theory it will give unlean sound(frequency other than harmonic of original signal).
Originally Posted by bimo View Post
No, 2200uF is enough for this 25Watt amplifier. More caps only give small benefit on bass at full power.
Old 19th June 2013, 03:51 AM   #53
apple1860 is offline apple1860
vred good
Old 22nd June 2013, 10:55 PM   #54
gootee is offline gootee  United States
You can just CALCULATE the minimum required reservoir capacitance, as in the linked post at
http://www.diyaudio.com/forums/solid...ml#post3532280
Note that the needed Vclip value is plotted in the LM1875 datasheet, versus the rail voltage.
LM1875 vs LM3886Hide this!Advertise here!
WTB: Pair of LM1875 or LM3886 cygnus x1 Swap Meet 4 7th December 2010 02:30 PM
LM1875 sound better than LM3886?? jamal Chip Amps 44 24th November 2010 05:14 PM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
Using the LM3886/LM3875/LM1875 for a HT amp set up diarav Chip Amps 5 2nd April 2006 04:43 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
