LM1875 vs LM3886
LM1875 vs LM3886
Old 1st November 2011, 05:55 PM   #31
sgrossklass is offline sgrossklass  Germany
The LM1875 is, interestingly, quite different from its newer "Overture series" brethren (which in turn all use the same basic topology). At the very least, the equivalent circuit looks a lot less intimidating, but there also are lots of other differences. Spec wise, the '1875 has a peculiar kink in its THD vs. output power graphs; as a result, distortion in the critical 1 W area is a lot higher.
Taking a look at pricing, the '1875 is a good bit cheaper (at least 1/3) compared to any of its successors, but as mentioned, for good reason. (Or maybe its internals have long since been replaced? It's not looking bad at all when measured here, even though the '3886 still does better at 4 times the gain.)
In which order did these chips appear anyway? There's a bewildering array, with at least the single amps 1876, 3875, 3876, 3886 and 4700 and the duals 1876, 4765, 4766 and 4780. All of them prefer the lighter 8 ohm loads, but for some reason 4766 and 4780 seem particularly bothered by 4 ohms if you look at 20 kHz distortion.
Speaking of the LM1876, this one actually finds use as output driver in at least one line of (well-reputed) commercial headphone amps, tweaked for lower gain.
As for the OPA549 mentioned earlier in this thread: en = 70 nV/sqrt(Hz), yikes. That's one noisy bugger, noisier even than ye olde LM386. Maybe that's why people like it, noise tends to "soften" the sound. Oh, and GBW = 0.9 MHz. Color me unimpressed.
Old 1st November 2011, 06:30 PM   #32
/grmbl @ edit time limit...
The measured LM1875 setup also had reduced GBW (via "small cap on input") to keep it stable, of course, so that probably compensates for the lower gain.
Old 1st November 2011, 08:49 PM   #33
tmblack is offline tmblack  United Kingdom
The lm1875 sounds great, but the LM3886 has an edge crispyness that is, well yikes!
Same for LM3776.
On the OPA549, sound is very good as a unity gain buffer. Use a good preamp for voltage gain.
Old 1st November 2011, 08:53 PM   #34
riverwarrior is offline riverwarrior  United States
Default 1875 vs. 3886
I currently have a pair of active speakers set up using the 3886 for the midrange, and the 1875 for the tweeters. I have been running this setup for about 2 years. Technical arguments aside, the 3886 is a much more functional amp for my purposes. The 1875 has a terrible thump at power cycling, and has necessitated a relay to protect my drivers. I would not recommend using the 1875 without some additional protection for any sensitive drivers.
Louis
Old 25th May 2013, 05:29 PM   #35
joar28 is offline joar28
Here is the LM1875 powered by a old pc-psu, I think it sounds pretty good. A perfect first time project.
LM1875 20W audio amplifier veroboard sound test - YouTube
Old 25th May 2013, 06:19 PM   #36
AudioLapDance is online now AudioLapDance  Canada
I don't know about the 3886 VS 1875 (I like both) but ...
I'm liking the 1875 right now: I get much lower offset (1875 : 5mV, 3886: 20mV), they're dead quite (no hiss, hum, or turn on/off noises ...) and cool as a cucumber!
1875, top, non-inv (full schematic--input AC coupling off-board), inv (minimal)
1875, bottom,, non-inv (full schematic--input AC coupling off-board), inv (minimal)
and I'm running them right up to their limits:
Spec: Vsupply max +- 30V
Me: +- 29V
Shhhhhh, don't tell Andrew ...
(+10% on the power lines and I'm done for!)
Old 26th May 2013, 07:33 AM   #37
R.I.P.
You have made and informed decsion. Noting wrong with that.
You have assessed the consequences and decided to accept the risk.
Again nothing wrong with making an informed decision.
regards Andrew T.
Old 26th May 2013, 07:40 PM   #38
I'm just yanking Andrew's chain , but given what's happening in the DC blocker thread I thought I better clarify.
http://www.diyaudio.com/forums/power...ml#post3505036
DON"T run your LM1875 at +/- 29 Vdc!
Your house voltage can actually vary quite a bit and +/- 10% is not unusual so for me my 111 Vrms could spike to 111V + 11.1V = 122.1 Vrms.
If you're using a chipamp with an unregulated powersupply (most are) this means that your chip ps voltages will also spike + 10%.
For an idiot like me that means 29V + 2.9V = 31.9 Vdc on my poor LM1875 (Max +30Vdc)!
This could cause the chip to fail.
Now we're into failure modes of the 1875: if you're super lucky nothing will happen, if you're slightly lucky the chip will just die and output 0 V, if you're lucky the chip will put out a small +2V glitch before it dies and hopefully your speakers survive ...
Now we get into the unlucky : if your unlucky the chip will put out +15 V for a while before it dies (do you like the smell of woofer in the morning?), if you're really unlucky it will oscilate / clip then put out +32 Vdc then die (hope you didn't like those tweeters too much?) and if your really unlucky something unpredictable and even worse will happen!
Now what I didn't tell you is that they're just hooked up to my lab speakers (no big deal), I've tortured them and they've survived and I've monitored my house voltage and it doesn't seem to spike (but it could!). So I'm not as insane as I first appear.
Hopefully that makes sure no one blows a chipamp.
Jeff
(Sorry Andrew, my previous post was a little on the irresponsible side. Remember, they're usually misinformed not deliberately trying to misinform.
Old 27th May 2013, 05:07 AM   #39
bimo is offline bimo  Indonesia
bimo's Avatar
My LM1875 amplifier:
It is best chip amp that I ever heard, but I have not try LM3886 yet.
Sadly, it was surpassed by my transistor amplifier easily.
Old 27th May 2013, 05:21 AM   #40
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Not a low-enough impedance PSU for the chip to give its best methinks.... More caps!
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
LM1875 vs LM3886Hide this!Advertise here!
WTB: Pair of LM1875 or LM3886 cygnus x1 Swap Meet 4 7th December 2010 02:30 PM
LM1875 sound better than LM3886?? jamal Chip Amps 44 24th November 2010 05:14 PM
lm1875 siemensc65 Chip Amps 4 23rd May 2006 03:28 AM
Using the LM3886/LM3875/LM1875 for a HT amp set up diarav Chip Amps 5 2nd April 2006 04:43 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
