MiniRef Schematic and PCB layout - Page 3 - diyAudio
Old 14th February 2012, 03:49 PM   #21
Send a message via Yahoo to linuxguru
Nope, that PCB vendor wasn't interested in a low-volume prototype run, and I didn't follow up because I got busy with the MyRef Rev E and other updates. I'll take another crack at getting it fabricated eventually - maybe after circuit updates (LM4766 maybe?).
It has been simulated, so it will most probably work OK. However, I can't predict if the sonics will be comparable to the MyRef Rev E with the latest upgrades.
Old 14th February 2012, 04:19 PM   #22
Ah, thats a shame...
I assume MyRef Rev E is Evolution? I like to stay away from SM components Until I get a bit more experience with through hole that is...
Do you have the Eagle files for this design?
Thanks,
Chris
Old 16th February 2012, 11:56 AM   #23
MyRef Rev E is actually just a modified compensation schema, derived from (but not identical to) Dario's alternate Rev FE BoM. It involves just 4 component changes to the Rev C BoM, and can be retrofitted relatively easily to existing Rev C boards - no need for SMD stuff.
The changes and impact on sonics have been discussed in some of the MyRef threads - most agree that it is an important improvement in audible sonics.
Old 16th February 2012, 12:04 PM   #24
Oh wow, I was unaware. Thanks
Is there a location where an up to date Rev E BoM is located?
Chris
Old 16th February 2012, 01:14 PM   #25
Rev E should be considered experimental even now, in that the optimal values are not firmed up. However, the values I've been using are summarized in the following posting. Start with the standard Rev C BoM, and change only the 4 components mentioned in the post:
My "audiophile" LM3886 approach
Old 18th February 2012, 09:56 AM   #26
Your listed reasons on the very first mail for why this new version are excellent and also intriguing.
1) Why not build a version for the 3886 too? Having both channels on one single pcb is better in all respects, so I wouldn't restrict it to the smaller powered chips.
2) How does this version, even with 1875, compare in audio quality with a "full" MyRefC?
3) Have you tried the LM318 on this version and compared it in audio quality with the other chips?
Old 18th February 2012, 01:10 PM   #27
1) With a pair of LM3886s, it will be similar (but not identical) to the MyRef Rev A. It won't save much on cost, and it won't be as good as the Rev C or later monoblocks. However, the LM4766 is an excellent alternative, at ~$5 per dual-channel chipamp, which should be able to deliver at least 30W + 30W into 8 ohms in this topology.
2) In simulation, it looks pretty good. It's possible that it might come close to some early Rev C builds on sound quality, with suitable high-performance opamps instead of the OPA2134. I wouldn't claim that it can compete with souped-up premium MyRef Rev C/Rev E builds.
3) Nope, I designed it to use DIP8 dual opamps, where there's a wealth of choice. The LM318 is a somewhat unique choice, which needs the (slightly elaborate) Rev C compensation schema to deliver the outstanding sonics of the MyRef.
Old 18th February 2012, 02:34 PM   #28
I tell you this because my MyReF, which I bought on eBay, uses one single pcb to house it all, and it follows the latest version, I think it was C at the time I checked.
The only thing that they share is the output relay, as I think was done on the first Penasa version. The rest is completely separate for both channels.
PCB size is 150mm x 95mm.
Old 6th June 2012, 08:16 AM   #29
hi siva,
remember me,i tought of just check out your miniref design. siva when you have designed the current pump you have changed the gain of the pump to 2 but mauro designed the current pump to have unity gain so that higher bridge outpu impedance of 500ohm was attainable right?have you checked on that?
then why have you used those 22nf cap in parrel with 220uf ....i know 220uf is for unity DC gain
should that cap come in parrel to 12k res
Old 6th June 2012, 02:16 PM   #30
Hi Vishnu: note that the Miniref is not the same topology as the MyRef, although many ideas have been borrowed from it. The Miniref is actually a nested Jung-topology amp, with both the inner opamp and the GNFB loops being non-inverting voltage-series feedback loops. The Howland current-pump (LM1875) is also non-inverting. The transconductance (I/V gain) of the Howland pump (as shown) is the same as that of the MyRef - this has been done to allow the use of existing MyRef parts without change.
I'm not sure about what you mean by bridge output impedance, but if you mean the output impedance of the Howland current pump, it's pretty high (comparable to the MyRef) and depends largely on the matching of the Howland resistor network (which can be matched to the same accuracy as that of the MyRef).
The 22nF cap is just a HF bypass for the 220uF DC blocking cap. Depending on the quality of the DC blocking cap, its use is optional. If the DC blocking cap is a Black Gate, Elna Cerafine, Panasonic Pureism or Nichicon KZ, you can probably omit the 22nF bypass. For a Panasonic FM, Elna Silmic/RJH/RJJ or similar, you may want to use the 22nF bypass - it's a matter of personal taste.
The 12k gain-setting resistance doesn't need a cap in parallel with it - the compensation schema for a Jung-topology amp is very different from the MyRef, and is provided by a single modified-Deboo integrator, which is the 22pF + 1k network in this schematic. In simulation, it has a fairly comfortable phase-margin of 80 degrees or so, which can be increased further if needed.
Note that a double-sided PCB with careful layout is mandatory if you want decent sonics. The topology is fairly forgiving with respect to stability, but the parasitics from a point-to-point build can lead to unpredictable sonics.
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
Can someone check My PCB layout against the Schematic for mistakes please?? Minion Solid State 9 6th June 2007 03:26 PM
need a signal generator pcb layout or schematic hizz_eye Solid State 8 3rd March 2005 06:09 PM
Denon PMA 770 - Schematic & PCB layout - Anyone got one? GeorgeBoles Solid State 1 29th September 2004 11:50 PM
Does anyone have a schematic or pcb layout for eq punchpeanut Parts 3 22nd September 2003 08:20 AM
Copyright 1999-2017 diyAudio
