Impedance matching
Dear friends,
A while back, I built some gainclone amps that all seem to be working well.
Recently, however, I came across impendance matching. I read that the output of the source i.e. pre-amp should be connected to the input of an amp where the input impendance should be 10x higher. e.g. should the pre-amp output impendance be at 47k ohms, the amp input impendance should be 470k ohms.
Am I reading that right?
How and where is input impendance on gainclones measured?
On my gainclones I am using for the input to ground resistor a 22k ohms and for the Rf resistor a 22k ohms.
Please excuse my ignorance due to my being a novice.
Any and all assistance will be appreciated.
Impedance not impendance.
Yes you are reading that right, but it is not critical. Input impedance=output impedance is OK. Input impedance < output impedance is to be avoided generally.
How and where is input impendance on gainclones measured? On my gainclones I am using for the input to ground resistor a 22k ohms and for the Rf resistor a 22k ohms.
The input impedance is probably 22k, but this depends on the exact circuit. Learning to calculate the input impedance is not simple. Have you got a volume control? Post a drawing.
Everyone was a novice once, no-one minds honest questions.
w
Joined 2009
Speaking line connection we try to send a VOLTAGE along the line.
When you connect gear together you're creating some voltage divider which formulae is R1 / (R1+R2) (edit: in fact Z1/(Z1+Z2) because we are speaking of impedance (Z) but to symplify we consider it as a resistor... ).
If source output Z (preamp : R2) is way lower than load input Z (amp: R1) voltage transmitted along the line stay near unity gain eg: 1v x 1~ 0,9 =1v~0,9v.
If your output Z is equal with your load Z you get HALF the voltage sended (you lost 6db along the line) at input of the amp (for 1v at preamp output you get 0,5V at load).
If your output Z is way higher than your load input Z you divide the signal many times more resulting in voltage at load very small (highly attenuated eg: 1volt preout and 0,01V at amp input).
You could think this is not a problem since next stage (in our example preamp/amp) will amplify signal, but modding the impedance ratio you modify frequency response too (Impedance Z is the sum of all L, C and R of a circuit) and so you modify signal frequency reproduction ( eg you may loose some bass and high end).
The ratio 1/10 is a general recommendation allowing you to be in a 'safe spot'.
In fact in pro gear for line you could find 10r out Z and In Z up to 50K or more: ratio is bigger but voltage divider is much more unity gain (voltage multiplyed by 0,998). As long as you stay in ratio 1/1 to 1/10 it's ok.
My appreciation
To wakibaki,
Thanks for your clarification on the matter. As well thanks for your correction of my spelling.
To krivium,
Thanks for a formulating explanation to the issue.
There are no volume controls on any of the gainclones directly. The signal travels from an Onkyo receiver's pre-amp outputs to a pair of Behringer CX 3400 3way crossovers - one per side - and down the chain to the gainclone amps.
As for schematics, I didn't do any drawings as I followed those available on the Internet.
having used them for over a year, approximately 12 hours a day each day, there have been no issues whatsoever. Clean sound. No hissing or hums.
Thanks again.
Taeedy.
you quote output impedance of 47k.
I think you have mis read this specification.
I think 47k is the recommended load impedance the source should be connected to.
I further suspect the actual output impedance of your source is less than 2k and probably less than 500r.
I prefer to use higher than 1:20 but as said earlier that ratio is not critical. In professional audio it can approach 1:100000, i.e. output impedance 10r, input impedance >1M (balanced transformer).
