Old 21st February 2011, 11:30 PM   #1
bs1777 is offline bs1777  Canada
Default Need amplifier.
Im am looking into buying and amplifer. It needs to be 2 channels with (at least) 100 watts PER channel. It also needs to 4 ohm stable PER channel. My budget for it is MAX $200. It doesnt have to be the best name in the world(Pyle is ok). And it needs to have some feature like RCA's and maybe a display.
-Thanks
Old 22nd February 2011, 03:05 AM   #2
Also its for the home.
Old 22nd February 2011, 05:46 AM   #3
Used. Technics (and others). eBay.
Old 22nd February 2011, 10:59 AM   #4
Bone is offline Bone  United Kingdom
This is supposed to be a DIY forum. Make yourself something!
Old 3rd March 2011, 01:11 AM   #5
After doing some research, making something is so much more expensive and time consuming.
Old 3rd March 2011, 01:20 AM   #6
ostripper's Avatar
-Thanks
Do what I just did , I got a burned nikko alpha 230 for $23. Gut the amp , reuse the trafo , heatsinks , case and put your own amp into it.
Here is another one ... Soundscraftsmen RA5502 Power Amplifier 1/4" input jacks - eBay (item 170608090092 end time Mar-06-11 14:21:27 PST)
That SC 5502 would be perfect for a 4 OP device stereo pair (120w/8R).
What I'm doing for the nikko or would of done for the SC5502 will only cost me about 120-150$. Just some fancy custom PCB "magic".
OS
Mongrel website , always current and updated :
http://67.248.209.21/D%3A/WEBSITE/
Old 3rd March 2011, 09:48 AM   #7
Buying working second hand is probably cheapest, unless someone is giving it away.
Buying a non working "donor" amplifier is probably next cheapest.
The amplifier inside the "box" may be worth no more than 10% of the total value of the "box".
Replace the amplifier and you have all the other bits for just a few $/£
regards Andrew T.
Old 3rd March 2011, 11:51 PM   #8
I do gave a sony Hi-Fi amp but it is 8 ohms for the output impedance. If there a way to change it? and thanks ostripper for the feedback, but it would be great if you could go into greater detail with the whole amp thing.
-Thanks
Old 5th March 2011, 10:06 PM   #9
I have found out i have a bigger budget too. Anything under 300$
Old 5th March 2011, 10:49 PM   #10
MJL21193's Avatar
I've got a Yamaha HTR-5760 that you could have for $300 plus shipping. 7 channels, 110 watts each. Specs HERE. Complete with remote.
Not much around here that is better, especially at that price.
Wanted: DIY amplifier builder with experience. I need a 0.7 ohm stable amplifier Audiophilenoob Swap Meet 34 16th May 2005 11:58 PM
Questions about how to decrease the PASS A-40 amplifier into a class AB amplifier. novtango Pass Labs 2 21st October 2002 01:50 AM
Page generated in 0.11318 seconds (79.27% PHP - 20.73% MySQL) with 10 queries
