Old 21st February 2011, 07:57 PM   #1
OMaudio is offline OMaudio  Germany
Default speaker pop LM1875
Hello,
i have a speaker pop by Power OFF!
What can i do?
Regards Olaf
Old 22nd February 2011, 10:32 AM   #2
not turn it ON, or not turn it OFF.
You choose which option suits you better.
regards Andrew T.
Old 22nd February 2011, 12:45 PM   #3
pmbrunelle's Avatar
Use a relay to disconnect the speaker when you turn off the amplifier.
A simple way would be to use a mains voltage relay (switching the speaker outputs), connected in parallel with the transformer primary.
Then, the relay will turn off (and disconnect the speakers) before your capacitor banks discharge.
I wouldn't fuss with it for a woofer (who cares) or multi-way speaker. Only if the amplifier is driving a tweeter.
Old 22nd February 2011, 07:25 PM   #4
Had a bad day?
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 22nd February 2011, 08:36 PM   #5
Hi
I use this circuit with my tda2050 sytem. It's simple and have few components.
Features
DC protection
Delay Power On
AC cut Off
No Pop On-Off
Tested!
Files attached
Last edited by electroconico; 22nd February 2011 at 08:49 PM. Reason: Files attached
Old 24th February 2011, 01:51 AM   #6
Try to use a bleeder resistor across the PS capacitors. They will discharge the capacitors faster minimizing the noise.
Old 25th February 2011, 04:35 AM   #7
Here´s a short video of the speaker protection
The hard click noise is from ac main switch , the soft click is from relay.Dlay +- 1.5seconds
regards!
Old 25th February 2011, 04:46 PM   #8
This must be a misunderstanding. The bleeders discharge the capacitors when the amp is switched off. Noise should not be an issue by that time. While the amp is on, the bleeders do nothing except convert some electric energy into heat. They don't reduce noise.
Old 25th February 2011, 06:03 PM   #9
I listen to your video and the only noise is the mechanical noise. It is what the noise your are talking about? I can not heard the speaker noise.
Old 25th February 2011, 07:18 PM   #10
Yes , only mechanical noise, no pop on-off noise. There´s a soundtrack.
Let me do a better video.
Speaker snap or crack (no pop) sneakers563 Tubes / Valves 7 5th November 2010 09:11 PM
LM3875 speaker pop when powered on JDawg Chip Amps 36 14th September 2010 03:26 AM
Marantz 2245 crack and pop on Left speaker yklou Solid State 7 21st January 2010 09:36 PM
Speaker Pop! AmpBuilder225 Tubes / Valves 0 18th May 2009 08:28 PM
LM1875 power on POP problem AndrewGM Chip Amps 6 16th May 2009 04:40 PM
Page generated in 0.10445 seconds (77.39% PHP - 22.61% MySQL) with 11 queries
