| Chip Amps Amplifiers based on integrated circuits |
Hey guys, I'm pretty new to the DIY audio scene. I'm building a carputer to control audio/video in my car and have to make an amp to amplify the motherboard outputs. I'd like to get 4 channels at 100w rms. I was thinking about building a pair of 41hz Amp10s based on tripath 2022 chips, but it requires 35v input. Unfortunately, in a car environment, we are limited to 12v DC. What're would be the best solution for boosting voltage? Is there a better option than Amp10 to get 4x100 rms watts? I'd rather not just go buy an external amp cause I need to integrate this into the computer case (small space). Thanks in advance!
Sent from my Droid using Tapatalk |
#2 |
You have three options in a car. A single ended amp will give something like 4-5 W into 4 Ohm, a BTL amp will give something like 16-20 W into 4 Ohm and the third option is to use a DC/DC converter that steps up the voltage. That last thing is pretty much an SMPS and commercial amps contain it for high output power. You should find such a thing in electronic stores.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
| f/s Hlly t-90 tripath 2022 amp | mfong | Swap Meet | 4 | 9th April 2010 12:55 AM |
| Resistors burned up on Tripath 2022 kit | ozerik | Chip Amps | 1 | 3rd August 2009 11:19 PM |
| need advise: 3-channel tripath with 12V power supply | smoerk | Class D | 7 | 17th August 2007 03:06 PM |
| tripath 2022 kit | snivit | Digital Source | 1 | 14th June 2005 09:11 PM |
| class t 2022 tripath | snivit | Class D | 0 | 7th May 2005 10:26 PM |
| Page generated in 0.07081 seconds (70.75% PHP - 29.25% MySQL) with 10 queries |
