Gain of inverting amp - diyAudio
Old 29th July 2003, 11:16 AM   #1
Default Gain of inverting amp
Hello All,
I am still in the process of making my first GC for an active system.
I have worked out that the amps for the tweeters only need to be app 20 watts rms.
I will be driving the system from my XA333ES SACD player which has a 2 v rms output which I will need to pad down.
From my initial calculations I have found I only need a gain of 9 to get full output with a 1 volt input.
Am I better to reduce the input voltage to 0.5 volts max and have a gain value of app 17.
Any help would be appreciated.
Blair
Old 29th July 2003, 02:57 PM   #2
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
For use in an active speaker system where, presumably you will want the amps close to the drivers, I would recommend using the non-inverted design.
The alternative is to put a buffer before the inverted power amps.
I would just buld the amps with equal gain and then if you need to adjust the tweeter levels, put in some sort of volume control after.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 30th July 2003, 07:11 PM   #3
Hello Nuuk,
please excuse my ignorance if I ask why the topology of the non inverting amp is prefered to the inverted design for an active system.
Can you please explain.
Blair
Old 30th July 2003, 08:01 PM   #4
Nuuk's Avatar
Hello Nuuk,
It is because with the inverted design, the feedback loop includes the items which preceed the amp, like the interconnects and the volume control.
As one of the big advantages of active systems is to have the amps as close to the drivers as possible, this would mean using long interconnects which could effect the performance of the IGC.
Of course, this may not be the case if you put the active crossovers immediately before the IGCs as they would act as a buffer, isolating the ICG circuit from the cables. But it needs somebody more experienced than I am to confirm this.
Old 31st July 2003, 12:50 PM   #5
moamps is offline moamps  Croatia
Are you sure?
Old 31st July 2003, 12:58 PM   #6
Previously: Kuei Yang Wang
Konnichiwa,
We have been there before and I must note again that while this view is readily promoted by a fairly high profile poster it is nevertheless absolutely and utterly wrong. The FEEDBACK loop is from the output to the inverting input, REGARDLESS if the Amplifier is inverting, noninverting or pseudo balanced Input.
You are talking about the input loop and that again is the same in all essentials for inverting and noninverting mode but differs for pseudo balanced. What MAY need to be addressed is the circuit stability with open input for the inverting design.
Sayonara
Old 31st July 2003, 12:58 PM   #7
Cool one of the big advantages of active systems is to have the amps as close to the drive
its an advantage - but not big......there are several much bigger advantages in an active setup.......
Old 31st July 2003, 01:05 PM   #8
jan.didden's Avatar
If you are into very high-end (read: expensive) speaker cables, the advantage may be worth several 1000 dollars...
Jan Didden
Old 31st July 2003, 01:22 PM   #9
Old 31st July 2003, 01:38 PM   #10
Jan Didden
Longer interconnects are also expensive.
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 01:37 PM
whats the difference between inverting and no inverting mikee55 Parts 1 7th January 2007 11:36 PM
Aleph Phase Inverting / non inverting macka Pass Labs 9 22nd February 2006 08:01 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 07:53 PM
Reducing the gain with an inverting gainclone Bricolo Chip Amps 10 1st December 2003 05:58 PM
Copyright 1999-2017 diyAudio
