Gain of inverting amp
Old 31st July 2003, 12:42 PM   #11
jh6you is offline jh6you
Account Disabled
Originally posted by janneman
high-end (read: expensive) speaker cables
I might arrange 5 different pairs of speaker cables connected to a rotary selector. Then, it could give a better opportunity for the amp gain control and, in addtion, another opportunity for an A/B/C/D/E test of the speaker cables. I hope this will help.
Old 31st July 2003, 12:58 PM   #12
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
What MAY need to be addressed is the circuit stability with open input for the inverting design.
Oops, sorry for that mistake. I have no electronics training and that is why I asked for some confirmation.
So what is the answer to the question? Would the inverted GC design work in an active system without causing problems with instability?
And what would be the best arrangement? Crossovers in preamp or immediately before IGCs?
PS I'm going out to get run over by a steam-roller so that I don't have such a high profile
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Old 31st July 2003, 01:04 PM   #13
tbla is offline tbla
Default $$$$$$$$$$$$
you need to wear shades with such a bright future.......
Old 31st July 2003, 01:17 PM   #14
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally posted by moamps
Longer interconnects are also expensive.
Touché...
Jan Didden
Old 31st July 2003, 01:22 PM   #15
moamps is offline moamps  Croatia
Why not? IGC has higher stability than NOINVGC. IMHO.
Because of that, you can place input chinch very close to output terminal. (additional weak NFB, maybe)
Second.
Old 1st August 2003, 11:53 AM   #16
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Konnichiwa,
Well, as said, the notion of all the stuff on the inverting pin being the feedback path has been promoted previously (not by you), but is is wrong. I suspect you read it before and simply accepted it.
Yup, will work fine. It MAY be prudent to raise the feedback resistor to 330k and to make sure to connect a 22k Resistor across the input. The resulting Amp will be unconditionally stable, even with no input conenction, though the input impedance drops from 10k to 6.8K.
Due to their very nature the IGC circuit can be adapted to operate as inverting (Rauch type) active filter. So if you want, simply place the filters for each band around the LM3875. The input impedance will now of course be all over the place, so the input to the various networks should ideally be buffered.
If the Filter Circuits are only supposed to be 1st order this is even easier. So I would always have the filters at or around the IGC. Unless I use a commercial external crossover, like the Behringer Digital DCX2496, in which case BTW I would recommend to use pseudo balanced inputs for the Gainclones.
I was not refering to your Profile (though truth be told you do contribute a lot).
Sayonara
Old 1st August 2003, 08:42 PM   #17
Nuuk's Avatar
Thanks for the clarification T. It just goes to show, you can't leave us to our own devices and it's a good thing that you monitor these forums on a regular basis
I doubt that I will be using the GCs in an active system as I still prefer the simplicity of using something like the Goodmans 201s but who knows where the holy grail will take any of us next!
Gain of inverting ampHide this!Advertise here!
sonic differences between inverting/non-inverting LM4780 VS both non-inverting LM4780 jarthel Chip Amps 5 19th July 2007 12:37 PM
whats the difference between inverting and no inverting mikee55 Parts 1 7th January 2007 10:36 PM
Aleph Phase Inverting / non inverting macka Pass Labs 9 22nd February 2006 07:01 PM
Bridged/Stereo, w or w/o servo, inverting 3886, inverting buffer PCB Alexander Rice Chip Amps 9 27th March 2004 06:53 PM
Reducing the gain with an inverting gainclone Bricolo Chip Amps 10 1st December 2003 04:58 PM
