| Chip Amps Amplifiers based on integrated circuits |
Any references to actual experience using the 3886 in a (simple) current drive (transconductance) configuration? In theory the feedback modification should be quite simple . . .
#2 |
It might be a question of whether the chip is stable when connected like this. In normal voltage-feedback use Nat Semi state that the minimum gain for stability is x10. What value of current-sense resistor will you be using in series with the speaker load?
I was wondering about trying one of my LM3875 boards to current-drive a speaker, to experiment with using a speaker having low Qe in an open-baffle. |
#3 |
frugal-phile(tm)
We (ie Daniel aka Duo) has a 3875 running as a variable transconductance amplifier. ie turn the knob all the way clockwise it is a current amp.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
#5 |
frugal-phile(tm)
There is a thread where generalities are discussed, youll need to search it down yourself. ETM's book, (thread on Vendor's Bazaar) also has some info on chip amp based current amplifiers.
dave
#6 |
You might find this web page to be a useful guide. Not for the LM3886 in particular, but shows how you can make a current source:
Variable Amplifier Impedance -Charlie |
#7 |
Tried search, didn't find your (looked like something specific, guess not) suggestion. Read the ETM thread (which seems to have turned into a pi**ing match between Thorstensomebody and the author) and have ordered the book. Also had read the ESP page Charlie linked . . . was hoping for something more specific (actually realized as a working device).
#8 |
Do a search on "improved howland current pump" and you will find much to read.
Here is a design Ive been looking at myself just havent had time to try it: http://www.cabezal.com/~inguz/amp/inguz_amplifier.pdf And another more complex design" Transconductance amplifier project - Current-Driving of Loudspeakers amt |
#9 | |
frugal-phile(tm)
A Transconductance Amplifier dave
| Is a single 3886 powerful enough to drive SS 18w-4531 ? | 100db | Chip Amps | 10 | 13th October 2007 04:02 PM |
| How many 3886 chips required to drive these woofers? | rhythmdiy | Chip Amps | 18 | 8th October 2007 04:07 PM |
| How much current draws a 3886 at 4 Ohm & max. power? | Bassterror | Chip Amps | 10 | 28th August 2006 12:32 PM |
| Drive current for MOSFet's | ifrythings | Power Supplies | 5 | 19th May 2006 07:36 PM |
| mix current drive with voltage drive at LF? | capslock | Multi-Way | 0 | 27th April 2006 10:17 AM |
| Page generated in 0.10899 seconds (77.14% PHP - 22.86% MySQL) with 10 queries |
