OP-AMP HEADPHONE AMP SUGGESTIONS NEEDED
Old 16th February 2011, 03:21 PM   #11
nightanole is offline nightanole  United States
Never did understand balanced speakers/cans. How do they work?
Old 16th February 2011, 04:31 PM   #12
qusp is offline qusp  Australia
qusp's Avatar
instead of the voltage being measured/referenced against ground '0v' the second wire that would be signal ground is actively driven in the opposite polarity by a matching inverted amplifier, so the headphone cable needs to have 4 wires, 1 for each phase per channel. so often the only reference to ground is in the power supply. then at the driver any errors that exist in both phases/wires are cancelled out (to the degree that the common mode rejection ratio (CMRR) of the circuit/device permits) when they are added together. that can be distortion, noise, interference etc. purists object that also some good stuff like 2nd harmonic distortion, which is pleasant to the ear, is also cancelled out and makes it sound sterile, i disagree.
so as a result you end up with a transmission line that has double the voltage swing (only if the power supply is doubled to drive the second phase), very low distortion and very good immunity to noise. i find that low level detail is preserved to a higher degree and that bass has more slam, an overall cleaner sound to these ears. then you also have the pass SuSy designs but you can search the pass forum for that, this is what is called a balanced single ended amplifier and that is the type of circuit that the opa1632 opamp in the board i posted uses.
as a result, with my portable headphone rig, not only does it sound brilliant, but i'm never bothered by that horrible cell phone interference when someone takes a call or sends a text, its cancelled out
hope that helps
Old 23rd February 2011, 05:46 PM   #13
rcollege is online now rcollege  United States
Originally Posted by horizonrays View Post
actually i want to know what happens in those circuits , after opamp ,
since op-amp amplifies the signal , and send it to transistor as most opamp cannot provide enough current to driver the transistor ,
but in the circuits i posted , two different approaches has been used , ib both circuits , transistors are given signal in two different way from opam, and actually i want to know the difference between them ,
OK...I'll take a stab at answering your question- Ther are more experienced people out there as I'm new to all this, but this is what I see-
All the schematics you posted are class A/B output.
So all use the NPN/PNP complimentary resistors.
The main difference I see is the amount of capacitors and filtering by the "added" circuitry of the more complex looking designs.
The other important difference I see is the amount of diodes...and one uses an LED (light emitting diode- which I add the def just in case).
The diodes cause current and voltage to continually keep the transistors active so you never have one fully off. This reduces crossover dstortion.
One uses 2 diodes, one uses one diode the other uses an LED. I have had success using all combos. So play around to find out what you prefer...Class B can sound suprisingly good if sensitive high speed transistors are used. Class B is when the transistor closes completely until enough voltage opens it...this ommits the need for the diodes and the two bases of the BJT's are connetced with nothing in between.
I have done a circuit for larger 2 way speakers- 10"woofer x 1"tweeter- 90db. I have driven this speaker directly from op amps. LF353 and TL082 were able to drive the speakers louder than you would like sitttin' with your ear to 1" from the speaker. So smaller transistors will only help and larger power transistors are not necessary- something that can be heatsinked will work fine...unless you do pure class B...then less heat is generated.
Just get a decent hfe and audio grade. Darligntons are ok...though I prefer straight BJT- richer smoother sound- at least I think. I've had the best sound with TIP41/42. MJ200/ 210 give decent sound and are smaller. I've driven smaller speakers with 2n3904 and 3906.
Another great sounding combo is NTE11/12- even in class B. They are high current and have a max ic of 5amps, but a low power dissapation.
(I know NTE is hated- but I haven't found the cross reference) Class B will give off very little heat. Just do a straight wire connecting the 2 bases of the BJT's.
I also keep my opamp designs very low gain. 1K - 1K....5k -5k on the feedback resistor/ gain adjusting resistor. Using +/-12 with a 2Vrms input results in 10V pk/pk. So I only need to amplify current This leaves me with 8.5V pk/pk after going throu the output BJT stage using .7ohm resistors on the emitters. This max volume results in zero clipping.
With an 8 ohm speaker I get 6.6V rms, 818mA rms wich translates into 5.39W rms. So I need to be sure everything can handle peak to peak ratings of 17v, 2.1amps. Then everything will be safe at full volume and will result in zero clipping. Class B will result in very little heat.
One thing that is important is the resistors on the on the emitters. This will help prevent thermal runaway should the resistors overheat. Though the risk is low at such low power, the last thing you want is to destroy your cans...especially when wearing them.
OP-AMP HEADPHONE AMP SUGGESTIONS NEEDEDHide this!Advertise here!
2x Gain pure op-amp headphone amp idea Dxvideo Headphone Systems 31 6th August 2017 05:09 PM
Poor power output, op amp based headphone amp. dannybeckett Solid State 13 27th September 2010 08:31 PM
Headphone Amp:njm4556s Op Amp For Rs1 And Others uhcmos Headphone Systems 7 19th October 2008 08:02 AM
your ADI op-amp suggestions, please dfeweer Parts 2 3rd August 2008 10:09 PM
Headphone amp with power OP? Zen Mod Headphone Systems 2 9th June 2005 02:15 AM
Copyright ©1999-2017 diyAudio
