| Chip Amps Amplifiers based on integrated circuits |
I guess it's steam technically. I built a chipamp using the circuit in the datasheet for LM1875, except that the only 50V caps I had for the power to ground filter were 680uF. (Not the power supply, that has four 2200uF caps in two banks of two in parallel). I thought there was a wide tolerance there on the amp board, which is point to point wired perf-board. After a few tests, fixing some cold joints, cleaning up some flux, I finally got the left side to work, but not the right.
I started testing to see if it was the source (an iPod), the speakers, or the amp when I got the funny idea to hook both speakers to one side. I reasoned that hooking them in parallel would result in half the impedance and thus more current, whereas hooking them in series would double the impedance and less current would flow. About 10 seconds after hooking them up in series one of the 680uF caps blew and the other was domed and hot. Any idea which part of my thought process was at fault? ![]() Thanks Ken |
#2 |
Well, I doubt it was anything to do with the speaker, but more likely the caps were wired backwards.
You have to give more detail to really make any progress. Exactly which schematic in the datasheet did you build?
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 |
Classic. You nailed it leadbelly.
Thanks, man! What a dope (me), Ken |
| Spain has gone non smoking | Reeler | The Lounge | 69 | 8th February 2011 02:22 AM |
| Smoking Transformer | JBLoudg20 | Tubes / Valves | 24 | 21st June 2006 02:59 PM |
| Smoking capacitors | jdoorn | Class D | 7 | 23rd January 2006 11:32 PM |
| amp smoking | biznatcher | Car Audio | 5 | 13th September 2004 11:48 PM |
| Smoking Amplifier | jkramer | Solid State | 0 | 23rd August 2004 02:37 PM |
| Page generated in 0.11844 seconds (46.53% PHP - 53.47% MySQL) with 10 queries |
