| Chip Amps Amplifiers based on integrated circuits |
I have just bought a TKD 2CP-601 dual log taper potentiometer to use as a volume control in an lm4780 based amplifier.
Could anyone advise me on which pins in the following diagram are input, output and ground please? http://www.hificollective.co.uk/pdf/tkd_cp6_data.pdf Thanks ![]() |
#2 |
The attached PDF (last image on the right) shows the pot and pin layout. Down below you have description on what pin goes where. Dual pot will have two rows, one is for one channel, the other one for the other.
#3 |
would I be correct in saying that pin 3 is input, pin 2 output, and pin 1 ground?
#5 | |
thanks for the help just done a quick test with some headphones and its working fine, also that board looks good, that was something I was looking for to save soldering directly to the legs of the pot!
| TKD 2CP-2500-S volume pot | Foto | Swap Meet | 3 | 28th May 2011 06:50 AM |
| Tokyo Ko-On Denpa (TKD) Products | Sellmark | Vendor's Bazaar | 0 | 27th September 2009 03:40 PM |
| TKD 100K dual pot | 5u4 | Swap Meet | 2 | 23rd May 2006 01:49 AM |
| Fs : Tokyo-on Tkd Motorised Pot | diy guy | Swap Meet | 3 | 3rd September 2005 03:14 AM |
| TKD (Tokyo Ko-On) P2511S attenuator | damento | Swap Meet | 3 | 2nd August 2004 03:30 PM |
| Page generated in 0.08672 seconds (76.38% PHP - 23.62% MySQL) with 10 queries |
