Old 2nd February 2011, 06:47 PM   #1
ianpengelly's Avatar
Default 4 Channel PA150 Construction Diary
Having been the proud owner of a chipamp for a few years now, I have decided to delve in a little deeper than before. My current amp is a LM3886 based design using the BrianGT kit and it has done well thus far. For those that are interested, there is a construction diary here:
Yet another 3886 gain clone!
However, whilst browsing away one day I came across the BPA300 thread and then the group buy for the boards with SMD components. This was early last year and through one reason and another I haven't gotten round to doing anything with them. A friend of mine was recently on the search for speakers and then decided he needed a new amp to go with it and this gave me the opportunity to pass my old amp on to him (albeit modified) and start afresh.
So this thread is going to be dedicated to the construction of my new amp, which will be based around the 4 PA150 boards, allowing me to bi-amp my Amish 45/97s. Also, there will be the off aside as I modify my old amp for my friend, as he has a special requirement in that it needs a summed mono output for his sub-woofer.
Back to the main event and the overall design will a two box amp, however, it is not going to be a pre-power set up, like my current arrangement, which makes use of an buffered preamp:
OPA627 Buffer Based Preamp
This will be an integrated amp, with the 4 amp boards, pre-amp, volume and source selector all in one box and the power supplies for the various sections in another box. The idea being to separate the noisy circuits from the less noisy ones, very much along the Naim philosophy, to name but one.
So my order from RS arrived today with pretty much everything I need bar a couple of power connectors for the multicore umbilical cord that will connect the power supply to the amp. I am pretty much decided on the case from Hifi2000, but haven't determined the layout I want to use or what I want etching / machining on the front, so that may cause a hold up... that and having to do some repairs to my en-suite
In the first instance I am going to be recycling the power supplies from my exisiting amps (a 225VA tranny and associated parts have been procured for my friends amp) with the intention that I can easily upgrade that box in future without having to disturb the amp itself. Its a good starting point as it'll contain 2 x 300VA transformers with rectifier boards and a regulated 15V power supply for the buffer circuit. Shine7 who built the BPA300 monoblocks on his website went for massive power supply capacitors, but I seem to recall that these chips don't require huge amounts of storage, in fact if you look at the aclaimed Peter Daniels amps, they have very little. I think a bit more research or experimentation may be required when I get to that stage.
Anyway, enough for now, photos of bits to follow!
Old 2nd February 2011, 06:58 PM   #2
Oh, actually... this is the case I am thinking of in black 2U with the 10mm front and 3mm top and bottom:
modushop.biz
modu
And this is the inspiration:
DIY BPA300 6x LM3886 300W audio Amplifier
There are a few other considerations that I might give to this amp as well including the lightspeed style attenuator or possibly a remote control feature, maybe both. I am hoping that I can retain flexibility in the design such that upgrades / modifications are easy to implement. Lets face it there is a lot to experiment with, valve buffers discrete op-amp replacements, bridging and electric crossovers!
Old 2nd February 2011, 08:46 PM   #3
As promised a snapshot of the parts, not all, but the main bits. The strips to the top righthand side are the SMD components, which I am really looking foward to soldering!
Also fun to fit to the boards are the input caps, which are huge!! Guess that means I can do away with the cheap electrolytics that I currently use for DC blocking.
Old 5th February 2011, 05:09 PM   #4
Default Lots of soldering
So I spent some time the other night and today oldering the components to the boards, which mostly went well, however there were a couple of challenges. The most frustrating was that a few of the square pads didn't want to take the solder which is clearly not good, however, I got there in the end.
The second was working with SMD components, which are easy to lose, as I found out after a resistor went shooting off out of the tweezers I was using never to be seen again. I'll be making a small RS order by the looks of it to get some replacements, good job 5 is the minimum order. What I should have perhaps done before I started the SMDs was looked to see if anyone had done a guide, as I struggled through 2 of the boards before figuring out my workflow. I'll share my findings:
  • Tin one pad
  • With the component in the tweezers move it close to the pad
  • Then heat the pad and move the component into place
  • Remove the soldering iron and keep the tweezers steady
  • When the solder is set then remove the tweezers and you can solder the other side
This has the advantage that the components should sit flush with the board and you can position them neatly. I found it efficient to do a few components down one side, then turned the board around to solder the other side.
One ommisson you'll see on the boards at the moment are the output resistors, this is so I can set the offset of each chip before they are all linked together. At some point I need to set all my trim pots to a central position.
I also need to find somewhere that stocks terminal blocks for the power and speaker connections with 9.5mm spacing, so if anyone can point me in the right direction or propose an alternative I would be greatful.
Old 19th February 2011, 10:05 PM   #5
Default Slow but steady
Its been a little while since I have updated this thread, mostly because not very much has progressed in the last couple of weeks thanks to needing to do some other more pressing DIY jobs, like fixing my shower.
Anyway, as I said earlier there will be a couple of builds in this thread and at the moment that one that I have been progressing with is the front end circuitry for my friend's amp. This is a going to be a buffered chip amp using the LM3886 boards I already have, but with a mono sum output for a sub.
I have now completed (fingers crossed) the board that will drive the front end, which is based around an OPA2134 to drive the chipamp boards, then a combination of a OPA2134 and OPA134 to created the mono sum. I decided that I would use the 2134 to act as a buffer and prevent crosstalk between the channels, then combine them and drive the mono output using the 134. A block diagram attached illustrates the layout.
I have not tested this yet as I need to sort out the front end power supply. But basically this circuit will take a feed from the power supply for the chipamp boards and then regulate the voltage down to +/-15V to to power the op-amps. I've knocked up the regulator and op-amp circuits on some breadboard.
Old 4th March 2011, 11:48 AM   #6
Right, still far too many things going on for me to have made much progress with this, however, I have decided on and gotten the power connectors to link the box that will contain the power supply to the box that will contain the amp. A number of factors affected the choice, but in the end it came down to availability. The choice is the 8 pole speakon connector which gives me 8 connections all rated at 30A at 250V, which should be more than sufficient for what I require. What this will allow me to do is use 3 poles for the regulated feed for any preamp circuitry, then 5 Poles for the dual power supply for the amp boards, by using a common 0v rail.
The connectors are fairly substantial and now I need to decide how I am going to wire them to keep the low voltage low current away from the higher voltage high current lines. Perhaps it isn't really necessary?
I haven't ordered the case yet either as I need to decide how I want the front to look and if I want it engraving or lettering, the latter most likely. Also, I have been on the search for a suitable power switch and the one that I like was typically out of stock and was also £25!
Old 21st March 2011, 08:30 PM   #7
Yikes, 17 days since the last update... how very poor!
So, what has happened since the last update? Umm, not much. I have gotten around to progressing the power supply that will power my friend's amp, which will also be used for testing the PA150 boards. Twin bridge rectifiers feeding two 4700uF caps with 1000uF as bypasses. I need to add a couple of resistors to drain the caps when the power is turned off.
Old 21st March 2011, 08:32 PM   #8
And another photo for fun!
Old 22nd March 2011, 04:44 PM   #9
rodolfo is offline rodolfo  Mexico
wow very nice job
Old 31st March 2011, 08:47 PM   #10
Yay, I have made some more progress! I finally found some terminal blocks for the boards. After searching for ages for something with a 10mm pitch (as per the instructions) I figured out that they are actually 9.52mm pitch and got just what I needed from RS. With having the power supply for my friend's amp built, I decided I would try one of the boards and check it was working. All went to plan and I adjusted the little trim pots until I had a matching 15.0mV offset on all three chips. So now I need to do the same with the other three boards and then install the output resistors before I can get some speakers attached and try them properly!
Best get thinking about ordering the case ASAP!!
'LGT' Construction Diary ShinOBIWAN Multi-Way 1793 5th January 2012 05:29 AM
Page generated in 0.14546 seconds (76.02% PHP - 23.98% MySQL) with 11 queries
