| Chip Amps Amplifiers based on integrated circuits |
Ok I built my TDA1557q amp Verstärker Schaltplan using the design from here. When I first plugged it in and only one channel worked, so I messed around a bit and got other channel working. YAY i thougth, but after a day of jamming that poor thing on MAX i noticed one thing, the speaker which didn't play at the beginning was playing slightly silenter. So I decided that I messed up again and built another one, same problems as with the first. Also one thing I noticed that the membrane (i don't know how to call it) on the bad channel is slightly higher than on normal working one.
Here is what i did No bridges and the soldering is fine. I cleaned the flux with acetone, and let everything dry/vapor off. Used a bigger heatsink with fan. Checked the plugs. nothing helped. |
#2 |
This sounds like DC at the output. Strange that it would happen on only one channel and on the same channel on two different amps. Due to the small number of components there is little you can do. Disconnect the speakers and measure the DC voltage at the output with and without C1 on both channels. According to the datasheet you will have to accept up to 250 mV of DC which is pretty high. The voltage at pin 12 should be half the supply voltage. Check whether that is the case with and without C1. If it is better without C1, skip it, because it is not in the datasheet either.
If you've always done it like that, then it's probably wrong. (Henry Ford) |
#3 |
Ok, I'll test it tomorrow, because I don't currently have an access to a multimeter and I have WAY too much homework.
#4 |
Yay, it worked, ThankYou
| 200w/8Ω smps & class d module debugging | authlxl | Class D | 24 | 8th June 2010 03:30 AM |
| Anthem Amp 2 debugging help | ronenash | Solid State | 20 | 23rd April 2010 01:09 PM |
| Debugging a PIMETA headphone amp | Atilla | Headphone Systems | 3 | 23rd April 2009 05:12 PM |
| Debugging my Aikido | Bas Horneman | Tubes / Valves | 38 | 1st August 2005 10:25 PM |
| Debugging Quasi amp | cm961 | Solid State | 7 | 3rd February 2004 11:54 PM |
| Page generated in 0.19357 seconds (28.72% PHP - 71.28% MySQL) with 10 queries |
