| Chip Amps Amplifiers based on integrated circuits |
not sure if a chip amp falls in the category?
What would be the best project 2channel amp that consumes the least power. I want something that sounds really good. It will be installed in my sailboat. |
#2 | ||
get an automotive amp
Look into class D amps. Andy Last edited by 4pyros; 27th January 2011 at 10:28 PM. |
#3 |
I want to build it, what kind of IC?
#4 |
Banned
#5 |
speaker efficiency is the larger variable, and listening area distance/room size - easily >100x differences in power required at the speaker terminals for different loudspeaker designs, application assumptions/requirements - so amplifier electronics efficiency is literally a second order effect
#6 | |
#7 |
Yes sailboats can be tuff. Bin thare done that. Try to keep the speakers above the water line, from the ceiling in the cabin. Outside thare are not to many options for touring anyway. Andy
| Leach Low-TIM amp with less power/lower voltage rails | prairiemystic | Solid State | 22 | 18th March 2011 06:54 AM |
| Precision Adjustable Low Voltage DC Power Supply | Stocker | Equipment & Tools | 0 | 19th December 2010 05:44 AM |
| Low Voltage High Power Supply | thndr | Power Supplies | 4 | 2nd February 2008 12:33 PM |
| Low Voltage (+70V) Power Supply Design | mwl6m | Power Supplies | 43 | 1st August 2007 01:00 PM |
| Simple Low Power Voltage Regulator | rjm | Power Supplies | 18 | 28th September 2005 03:48 PM |
| Page generated in 0.14971 seconds (46.52% PHP - 53.48% MySQL) with 10 queries |
